Old 01-31-2003, 08:24 AM
dionysis dionysis is offline
Rep: 44 Posts: 256
VPP's and wave drag...
Hi all,
I am in the process of developing a VPP for design purposes, and apart from the Havelock-Castles equations in Norwood's "High Speed Sailing", I can find little information on calculationg wave resistance for monohull sailing boats.
I like to be as exact as possible, so that changes to hull design are reflected in the vpp's results.
Am I forced into having to come to terms with partial differential equations, or is there a simpler way?
Cheers, and thanks in advance, dionysis.
Old 01-31-2003, 09:16 AM
nico nico is offline
Rep: 52 Posts: 186
Hi,
For the wave resistance you should have a look at the Delft series. It is a regression of the tank testing of around 50 boats and includes effect of (LWL,Cp,LCB,...) . I think it is what you re looking for. it is available in the Chesapeake Sailing Yacht Symposium proceedings and/or Larsson books and several others. If no one is availble to you , a can email you the set of equations and coeficients.
Nico
Old 01-31-2003, 09:36 AM
Rep: 44 Posts: 256
Thanks nico,
I have heard so much about this series, but have not been able to get my hands on it. Yes, your email would be much appreciated.
Old 01-31-2003, 02:10 PM
Mike D Mike D is offline
Rep: 458 Posts: 102
Nico
Like dionysis I too would appreciate a copy of the Delft series.
Thanking you in advance
Michael
Old 02-06-2003, 01:04 PM
Rep: 52 Posts: 186
Here it is
It is an excel spreadsheet
Old 02-06-2003, 08:29 PM
Rep: 44 Posts: 256
thanks nico
much appreciated nico, will sit down and make a study of your spreadsheet. Thanks again
dionysis
Old 02-07-2003, 08:17 PM
Rep: 44 Posts: 256
some questions about the spreadsheet
Hello nico,
Excellent spreadsheet, just some questions to clarify it's use:
On the data page:
for hull data : what does Tc, WA, T and form factor mean?
On the calc page:
1. What does Rv mean?, and in say, the formular Rv=Q4*hff, what does hff stand for?
2. What does the column Rresidual mean? Induced drag of hull, or wave drag?
Just two more questions:
I think the data: a0, a1,...a8 have to do with the 9 hull shapes of the delft series, but what do these represent? Do I need to know what they mean?
cheers dionysis
Old 02-08-2003, 09:40 AM
Rep: 52 Posts: 186
Hi
Tc canoe body draught
WA waterplane area ( not wetted area)
T total draught
Rv is the viscous resistance ( frictionnal + pressure)
hff is hull form factor ( account for pressure resistance)
Rv = Rf * form factor ( Rf = Rfrictionnal)
You don't need to know what a0,a1... mean, they are the factor of the polynomial regression to get the residuary resistance (=wave resistance)
Nico
Old 02-08-2003, 07:16 PM
Rep: 44 Posts: 256
excellent!
thanks nico, I owe you one
dionysis
Old 04-20-2005, 04:35 PM
MGLARRIBA MGLARRIBA is offline
Rep: 10 Posts: 2
Residual Resistance
Hi Nico
I have some information on the LARSON and ELIASSON formula to calculate residual resistance that i feel mest be wrong.
I have seen in an Excel sheet that you have offeres within this forum, that the third term, that says a2*LCB, comes with a minus (-) in my formula comes with a plus (+), can you confirm me the right one.
Also, can you tell me if the LCB dimension shown in the formula it's the position of the Center of Bouyancy as a percentage of the Lenght or it's an absolute value?, is it measured from the fore perpendicular or from the main frame in either of my previous question.
Old 04-21-2005, 03:19 AM
Rep: 52 Posts: 186
hello,
In the paper LCB is a % value and = (Lcb/Lwl)-0.5 with absolute value of Lcb and Lwl. In the paper a lcb aft of midship is by convention negative, so i just changed sign to put it positive (to my own convention: lcb aft is positive). (-*-=+)
Nico
____________
Nico
Old 04-21-2005, 12:13 PM
Rep: 10 Posts: 2
Thank you
Hi Nico:
Thank you for your comment
MGLARRIBA
Old 04-22-2005, 04:04 AM
grob's Avatar
grob grob is offline
Rep: 53 Posts: 211
Does anyone know where I can get info on the Gerritsma drag calculation scheme?
Old 04-22-2005, 05:44 AM
Rep: 52 Posts: 186
My spreadsheet actually uses the Delft series resistance scheme developed mainly by Prof. Gerristsma.
Several papers are at http://www.hiswasymposium.com/symposium_papers.asp
____________
Nico
Old 04-22-2005, 11:10 AM
Rep: 44 Posts: 256
Grob, thanks to Sorenfdk, go here:
There is a wealth of good info, but scroll down to the 1998 symposium papers and download 6- Approximation of the hydrodynamic forces on a saili...
It is a large 13 Mb pdf file, so I cannot attach it here. I think it is exactly what you want.
If you don't change tack, you will end up where you are heading.
