Old 01-31-2012, 06:08 PM
hailodintx hailodintx is offline
venture 17 Mods
Hello all new member to the forum here and I have a modification idea I would like feedback on. I recently acquired very cheaply a venture 17 sailboat. It turns out the swing keel it stuck in the trunk due to rust expansion, I have tried everything to remove it with no luck. My idea is since I really do not like the swing keel and the deep draft that comes with it, is to remove it completely along with the trunk and fiberglass over the hole. I would then add some internal ballast about 300# (slightly more than the keel weighs) amidships along the centerline of the hull. For lateral resistance I was thinking of using some Michalak style leeboards. Does this sound crazy? Is there even a small chance of these mods resulting in a functional sail boat. Also this boat would only be used on lakes and bays no offshore stuff.
Thanks,
James B
Old 01-31-2012, 06:49 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,603
From what I remember the V17 was pretty tender with the keel down-I'd be real leery of permanently raising the CG as high as you propose. Have you tried sailing in or floating the boat with the keel in the retracted position? That might give you and idea about how tippy it is. And beyond that, a lot of swing keel boats are hard to or impossible to right with the keel retracted.
I'd get some friends to help and pull the boat over with weight(a person or two) in the cockpit and see how it behaves. It will give you a feel for the boat before you do anything else. Good Luck!
yes, it is a revolution
Erikson 27 mods FrostFire Sailboats 4 04-29-2010 08:23 AM
Partner wanted in small boat building venture Tumblehome17 Boatbuilding 2 02-13-2009 11:52 AM
New Boat Start up venture 2cylmerc Boat Design 4 12-30-2008 04:03 AM
New Marine Venture Daniel Fenton Services & Employment 6 03-24-2005 11:18 AM
Join in a Co-operative Catamaran Build Venture! Neven Marketplace 0 12-17-2004 01:20 AM
