Old 11-05-2010, 08:14 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,603
Vang Spreader
Invented by Dave Lister(as best I can tell) and used on some Moths.
Here is an explanation by Phil S on DA:
The vang spreader was first used by Dave Lister, maybe 3 years ago. Works like any spreader on a mast. Widens the staying angle to reduce loads on components. It allows the vang strop to be attached further aft on the boom so that for the same boom section capacity you can get greater leach tension. It slightly increases the moment arm of the vang system so gives the vang more power too.
Basically increased vang power from existing boom sections and tackle.
Luka's boat is a work of art. Hundreds of hours by Luka and Marty in tooling and crafting a masterpiece. Marty's version will be ready in a week or so. These guys are not speedy builders but they set a high standard to follow. Lots of interesting tricks in the details are worth looking at.
Phil S
Moth AUS 3574, My moth Blog
IC/DC AUS 21, My Sailing Canoe Blog
2011 Moth Worlds Belmont NSW
http://www.luka-damic.com/
Picture from Luka Damics blog of his vang spreader:
(click on image)
yes, it is a revolution
Old 11-05-2010, 10:06 AM
cardsinplay cardsinplay is offline
da Vinci Group
Rep: -74 Posts: 330
It also puts more load on the boom gooseneck, adds weight to the boat and additional components requiring maintenance. As to the added function as a benefit, we'll just have to wait and see when the boat is sailed against the best rigs on the beach.
Then, there's also the reality that many of the best Moth riders are going to hard wings, making this vang approach old school before it gets to school.
Old 11-05-2010, 02:48 PM
Rep: 1493 Posts: 7,447
That's been used for decades.
Old 11-05-2010, 02:57 PM
Doug Lord's Avatar
Flight Ready
Any links/pix of other examples?
Old 11-05-2010, 05:45 PM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
Temple vang
Old 11-05-2010, 06:15 PM
Doug Lord's Avatar
Flight Ready
Not the same but very interesting...
Old 11-06-2010, 12:40 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
..the Sydney 12 footers are a radical bunch of nuts....i used to sail an 18, though we were pretty good, but watch the 12's for a few hours and you soon realise we were playing with ourselves, they really know how to sail to the X factor.......unreal to watch, but alas, I have never sailed one (did sail an 8 footer once at Woolwich, now that is simply stupid, 4 man boat).......
Old 11-06-2010, 01:33 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
Right on the money LandLubber http://www.skiff.org.au/photos/hotshots.htm check some of these shots for fun. Sailed along with(overtaken by) some replica 18's last weekend in the Balmain Regatta, there was one or two of the vintage 10's out too. You've only gotta look back in time to find a lot of this "new stuff" even the one footer/bugs & such in Aus exibited some of the "modern" concepts, like a workmate said "we can do stuff from the past, but we cant nessesarily do stuff from the future back in the past! I think he might be a budding Rap artist. All the best from Jeff.
Old 11-06-2010, 03:43 AM
Landlubber's Avatar
...hey, don't ya just luv it when the boat goes out of control, but is still upright!
I did that to the Bundeena ferry years ago with my Contender (KA2, Craig's first production fibreglass one)....I was only a skinny little fella then and a southerly came in that I simply could not resist, they backed up and the paggengers cheered as I "sailed" by, the rudder and c/board the only things that occasionally hit the water....Ya got ta luv 'em.....
Old 11-06-2010, 05:07 PM
It is a strut in a rigging part. Spreaders, dolphin strikers, etc. are all the same type of structure.
Old 11-06-2010, 05:17 PM
Doug Lord's Avatar
Flight Ready
The use of such a structure as part of a vang seems to be regarded as new in the Moth class which has been around for a while.....Have you ever seen a vang designed like the vang in the first post?
Old 11-11-2010, 04:24 PM
fastwave fastwave is offline
Rep: 36 Posts: 73
No I haven't,
but I like it. If i did it, I would improve it by replacing the stay with a carbon rod perhaps. Wait a minute. Then it would be an A-frame like the tempest.
Old idea perhaps
Old 11-19-2010, 05:46 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
I'm not buying any of these explanations. Not as actually executed on the boat.
1. Show me a mast with the stay attachment point half the distance to the load center with a spreader below that.
2. There will not be any load reduction except for a slight lessening of compression between the strop and the strut. The bending moments will increase at the strop and the strut. What will be affected is how the boom bends under load. It will bow down less at a given tension, meaning a stiffer feel and different gust response.
3. I don't see what the strut has to do with the strop location aft. It appears to be limited by the mainsheet geometry. Moving the attachment point aft lowers the tension only a little bit; but it can decrease the bending moment significantly. The ability to move the strop forward without having the boom tip deflection increase is a possibility. That might give more ducking under room during a tack.
4. Ok. The leach tension increase is on the order of 3% as built. It could be more with a different arrangement, so I'm thinking that is not the reason, either.
5. Nope, Static loads are higher. Might be offset by improved stiffness if buckling is a concern; but then dynamic loads tend to increase.
I came up with several different reasons one might want a strut; but when I designed the thing for the desired effect, they came out different from this one. One idea is using a rigidly attached vang strut to limit the amount the boom can roll about its axis- A solution looking for a problem.
Old 11-19-2010, 06:05 PM
Doug Lord's Avatar
Flight Ready
Phil, can you post an illustration of your idea?
Old 11-19-2010, 06:46 PM
philSweet's Avatar
Rep: 658 Posts: 621
Its just an effect of the geometry. Any rotation of the boom will move the end of the strut out of the plane formed by the gooseneck and the two attachment points. This will lengthen the path of the vang. You could use a line to the strut as a vang tweaker, or just let the vang hold the strut and thus limit boom roll to small angles. The attachment of the strut to the boom has to be rigid transversely. The strut doesnt have to be pushing the vang downwards for this to work. In fact, the effect is probably at a maximum if the vang is straight. On the moth, it appears the boom is pinned to the mast, preventing any roll. But the booms on many boats pivot freely.
Spreader positioning rickinnocal Sailboats 7 09-01-2010 09:33 AM
Spreader lengths Gashmore Boat Design 0 08-13-2008 06:38 PM
Spreader Orientation brawny84 Boat Design 7 03-29-2005 09:26 PM
Spreader to diamonds PhilT Sailboats 5 02-17-2005 08:39 PM
boom vang Pieetry Sailboats 6 06-30-2003 06:41 AM
