Old 02-16-2009, 11:12 AM
FemaleDuck FemaleDuck is offline
Useful thngs on a boat
I recently discovered a very useful thing to keep on the boat - releasable
cable ties. I've used the older type for ages, which have to be cut to get
them off, but B&Q now sell ones which can be released, and they work
brilliantly.
I wonder what little gadgets do you keep handy on your boats which seem
obvious once you've tried them, but eluded you before?
[url=http://www.waytomuine.com]Mui Ne Vacations, Mui Ne Travel and Tourism Guide[/url]|[url=http://www.waytovietnam.com/visa.asp]Vietnam tourist visa[/url]|[url=http://www.vietnambeachholiday.com]Vietnam Beach Tours,Vietnam Beach Vacations[/url]
Old 02-18-2009, 06:59 PM
Steam Flyer's Avatar
Steam Flyer Steam Flyer is offline
Rep: 10 Posts: 31
Originally Posted by FemaleDuck View Post
.....what little gadgets do you keep handy on your boats which seem
Releasable cable ties sound good.
Have you tried using them on crew?
Just kidding. The only "useful item" I can think of on my boat, other than beer, is a dispenser of window-cleaning wipes. They clean everything (although I don't recommend them on skin) including dinner ware.
FB- Doug
Old 02-18-2009, 08:04 PM
apex1
I recently have seen some collapsable kitchenware here in Istanbul. Bowls, deep dishes, colander and the like. The flexible ring was made of silicon stuff. If you ever tried to get some order in your galley cupboard, ever tried to find a proper place for bowls and colander, you spoke a curse upon them.
Regards
Richard
Old 02-19-2009, 10:53 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
brilliantly.
Not that it needs to be said, but Duct (gaffer) tape, electrical tape and a some Spectra for temporary rigging repair on the water. I keep a bunch of the plastic cable ties around - they make great temporary shackles.
Bill
Old 02-21-2009, 07:29 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
fuel usually eludes me when I go out but then I am reminded later that it would be nice to have. It used to be a big hassle on the 30' tub but now with the catamaran rowing is much easier.
Old 02-22-2009, 02:05 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Super C sweets, Vicks cough drops, tin opener, white gold sealed in plastic.
Regards
Fanie
Water ! Just gimme water !
Old 02-22-2009, 06:09 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Tiller extension for the o/b. Nothing fancy, just an aluminum pipe and a few hose clamps, with a rod down the middle for the kill switch. (It's amazing how quickly you can get tired out when you're trying to wrestle a 30-horse engine with your left arm two feet behind your back.)
Snap-in seat cushions. So much more comfortable than hard surfaces, and so much easier to keep clean and rot/mildew free than permanent cushions.
Disconnecting the gas line to the o/b 30 seconds before actually killing it. Gets the carb partly drained so you get a bit of fresh gas/oil in there when you go to start it a week later- no smoke, no fuss.
Old 02-23-2009, 02:58 AM
Fanie's Avatar
Fanie
I have installed a solid state fuel pump to act as a temporary pump when starting the outboard. Saves you from pumping the bulb to get fuel to the motor when you start. It also is a backup if the motor's fuel pump gives, at least you can keep the motor running.
Regards
Fanie
