| Unable to remove bung from thru-hull........ I put in a bung into a thru-hull while I cleaned the knot meter. My wife called me on deck and I pushed down the bung a little more firmly because I was afraid it might dislodge in my absence. I didn't get back to it for about 45 minutes and by that time it was firmly set due to the wooden bungs expanding. I've tried channel locks and vice-grips using moderate pressure. The wood is coming apart and I'm reluctant to use additional pressure. The thru-hulls are metal. Anyone have any ideas? |
| Unable to remove bung.... Sounds a daft idea - but try a good quality corkscrew. Failing that you may have to drill it out (carefully) and start again. ![]() |
| Removal? Similar to Bergalia's,idea: I have done something like this by driving four 2 inch drywall screws (or those nice stainless 'beaver bite' screws) thru a small piece of wood (pilot drill first) and into the part to be removed. You can tighten the screws a little at a time to pull evenly. Block the wood piece up on each end if you need more travel. Onboard, in Bergalia's frame of mind, I have also used the stainless steel screws in a true emergency when I lost the corkscrew, to open the wine. Worked fine!
| If that danged thing is still in there, drill a hole and stick a straight soldering iron in it. Alan |
| Chiming in with Terry, I've used soldering irons on occasion to open wine bottles, patch plaster, and even deliver Panda babies. Alan |
| Unable to remove bung.... |
| Forgot to mention. Sea Pandas, not the chinese ones. If you've ever taken one aboard, a pregnant one especially, You know how doggone hard it can be to safely deliver the pup at sea. I've tried all manner of contrivences---- marlinspikes, deck keys, even winch handles, but to tell the truth, than Sears soldering iron turned out to be the one item that did the trick time and time again. If you've ever been stuck onboard with an ugly-tempered mother Water Panda, you know EXACTLY what I mean. Those shifty, suspicious raccoon eyes staring a hole through you, the hot tropical sun overhead, the smell, my God, that smell! Besides, I'm saving this thread. How long do you think a thread on removing bungs from thru-hulls is going to last? Another hour? |
| This is a very common problem and one with wich I can sympothise with. A small stick of dynamite or other suitable explosive droped over the side within the viscinity of the affore mentioned through hull fitting should dislodge the blighter. On the other hand a 4 inch 12 wood screw screwd into the plug and a claw hammer with appropriate blocks of wood on wich to lever could work also. |
| In search of berries---- or perhaps a bit of panda meat. Or organ soup... |
| ATT email users may be unable to join or get topic updates via email | Jeff | Forum Questions and Suggestions | 1 | 01-22-2007 07:46 PM |
| Can't remove OMC cobra drive's HELP!!! | burt2 | Sterndrives | 2 | 07-17-2006 12:34 AM |
| how to remove sahft and plug | jeff1212 | Sailboats | 1 | 07-13-2006 07:05 AM |
| How to remove paint from the hull of a riveted aluminum boat? | whalepass | Metal Boat Building | 3 | 04-24-2006 10:23 AM |
| transom bung repair | cammo | Fiberglass and Composite Boat Building | 1 | 10-03-2005 09:39 AM |
