| Tumblehome in Performance Dinghy Hull Design Does anybody have any thoughts on tumblehome in performance dinghy design? I found an example here: New Rules IC
| The canoe is a little removed from the typical performance dinghy in that it uses the plank to generate righting moment and the loss of beam at deck level makes no change to this aspect of the boat.In addition,the self draining nature of the boat makes the shipping of water less of an issue.The slight saving of weight resulting from the reduction in total surface area of the hull and deck probably justifies the approach. |
Performance planing boats generally go in exactly the opposite direction to tumblehome, with wide flaring sides allowing a narrow beam at waterline and a wider hiking/trapezing platform at deck height. Canoes are a different breed entirely. |
| Don't say concrete
__________________ Gonzo |
| I won't! I promise!
| IIRC the IC rules don't allow flare. Adding some tumble home will help stiffen the panels without increasing the weight.
__________________ Chris Tucker Marine Design Your Boat Your Way. www.ctmd.com.au |
| tumblehome | dreamer | Boat Design | 17 | 04-11-2009 06:54 PM |
| Performance Dinghy Building Job Thailand | damon smith | Services & Employment | 3 | 11-08-2007 12:44 AM |
| purpose of tumblehome in runabouts | econologica | Boat Design | 21 | 12-15-2006 01:30 PM |
| Monohull Dinghy Performance Benchmark | Doug Lord | Sailboats | 0 | 12-19-2004 07:15 PM |
| Tumblehome | SuperPiper | Boat Design | 6 | 02-03-2003 10:21 AM |
