| Trolling motor for aux power Just curious if anyone out there would consider using a trolling motor as their auxilary power in a 16' daysailer. My thoughts would be to mount it to the rudder or at least have a mechanical interconnect between the sailboat tiller and the motor tiller to have the advantage or vectored thrust and rudder steerage. I see the advantage of reduced weight on the stern of the boat, as compared to a gas powered motor. Increased weight where it should be. i.e. the battery located down low and towards the center of the boat. Quiet operation. The addition of lights to the craft. A cleaner and less bulky installation than gas. Possible conversion to a solar charging system in the future. The main disadvantage that I see is the need to periodically recharge the battery. The boat is not a cruiser so I don't see it as a major problem. I'm open for input.
__________________ LP ---------- God bless the open minded people of the world. LP |
| You would have to strap the battery in very securely in case you capsize. You don't want it falling out or sliding around.
| Should work just fine , an AGM batteruy would work with out the chance of an acid spill. One HP from an engine will produce about 20 lb of thrust from a reasonable propeller. The electric motors are RATED in thrust , making the selection EZ. FAST FRED |
| I'll stick with a paddle, but it seems like a good idea that one, especially if you consider pollution and noise (or lack thereof) in comparison to petrol auxillary. One thing, though, how about charging it, have you considered how you will do that until you get the solar charging thing up and running? I mean, it's a small boat and all, and batteries are heavy. Or do you take your boat home with you (i.e. no problems then)? |
| Fred, I was hoping to get some positive response. Thanks for the numbers. I hadn't sat down yet to convert HP to thrust or vise versa. Yeah, I was thinking of going with a gel cell battery. In a standard lead-acid battery, I'd be concerned with battery fumes. Is this also a concern in an AGM type battery? DB, The boat is trailerable, so it goes home with me. I'll just get an inexpensive battery charger. I drove 12-14 hours one time to get down to the gulf of mexico and could only manage to wander around in the channel because the winds were squirrly and the current stiffled any progress we made. Long story short, a little bit of a kick would have gotten us out of the channel and on our way.
| I used a trolling motor (with lead-acid batt.) on my Coronado 23 for awhile with absolutely no problem. Pushed her right along! edit: It was20lb. thrust.
__________________ Imagination is more important than knowledge. -Einstein |
| I was using this trolling motor as an active rudder on my catamaran with very good result. |
| Kjell, With the standard propellers you are typically stuck at 2-1/4 knots. Yoke. |
| propellers Yoke, Are there different pitched propellers for trolling motors. I suppose trolling motors are pretty limited and specific in any change pitch to their propellers. A displacement hull would be easier push than a planing hull could, I would think, be able to accept a higher pitched prop. Is there an effect on power consumption? From your statement, it sounds like these motors are designed to operate at a max top speed of 2 1/4 kts.
| For what it' worth now, it is a 32# thrust, not 20. Don't know what I was thinking.
| The problem is that the thrust rating is only accurate at one speed. It could be at static power or it could be at a certain speed. There is a speed limit on any prop based on pitch and RPM. The drag of the boat obviously comes into play too. The point I'm trying to make is, a displacement hull offers lower resistance than does a comparable planing hull, would I be operating at a lower efficiency with a standard prop due to the fact that my mission is different from the trolling motors intended mission? And, if so, can I increase the efficiency by increasing the pitch of the propeller? (if such a beast even exists.)
From most literature that I've seen, the emphasis is on low speed power and dealing with weeds. (I think)Top end efficiency isn't part of the performance profile in a trolling motor.
| Thanks for the input. If your getting 3-4 kts with 32#'s on a 23'er, I shouldn't have any problem with 40#s on 16'.
| Trolling controls | Pete Katzman | Electrical Systems | 1 | 04-10-2006 06:15 PM |
| Sail power and horse power? | kjell | Motorsailers | 12 | 09-03-2005 04:20 AM |
| Trolling with Bayliner 175? | rmajoran | Powerboats | 11 | 04-21-2005 06:24 AM |
| help me ID this motor | don954 | Boatbuilding | 2 | 02-25-2005 05:13 PM |
| Trolling valves | Willallison | Propulsion | 17 | 02-27-2003 05:10 PM |
