Old 07-28-2009, 04:04 PM
drewcathell26 drewcathell26 is offline
Rep: 10 Posts: 17
Torrified Wodd
Is anyone using Torrified wood in boat building. From what I have read and seen to date it seems like it might have a lot of advantages to offer.
Old 07-28-2009, 05:12 PM
apex1
You cannot use it in boatbuilding (or construction in general), due to the higher brittleness and lower bending values. It is more or less a decorative wood with higher resistance to funghi, moisture, rot than the untreated timber.
Regards
Richard
Old 07-28-2009, 05:21 PM
Rep: 10 Posts: 17
I was thinking of it for use as a worm shoe where flexibility isn't an issue but the other aspects you mentioned might be a value.
Old 07-28-2009, 05:34 PM
apex1
Worm shoe? Tell a German what that is, please.
Old 07-28-2009, 09:09 PM
mark775
I had to Google "Torrefication". Amazingly similar to "toredo". Please reference; http://www.bayjournal.com/article.cfm?article=712
Old 07-28-2009, 09:46 PM
apex1
Thanks mark!
Of course, for that application the timber is a good choice! Some of the different timbers tend to resist Epoxy penetration when heat treated, you should make a test before buying a whole forest!
Old 07-31-2009, 08:35 AM
dskira dskira is offline
Rep: 1305 Posts: 1,363
I never find sacrificial worm shoe practical. The worms after changing the shoe, has a tendency to go in between the worm shoe and the keel, and mostly also the rot also start at the fastening holes. I prefer to put a very well bedded with roofing tar a steel bar and fastened with also well bedded screw. I had in my experience better result. A nice coat of black varnish or coal tar epoxy finish the job quite neatly.
But it is true that I know people who had very good result with classic sacrificial warm shoe, mostly in oak.
I find also that the worms like the stern post area, between the keel and the rudder. It seams always the open door for there own "restaurant" since at that particular place, the paint is always lacking.
Well my two cents
Daniel
Old 07-31-2009, 09:38 AM
apex1
Thats the place with the highest water disturbance, therefore the highest oxygen content in the water, which makes barnacles happy and paint corrode.
Old 07-31-2009, 02:20 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 561 Posts: 1,052
cavitation is a worms best friend
