Old 01-07-2005, 02:39 PM
Skippy Skippy is offline
Rep: 12 Posts: 568
top-pivoted leeboards
I've seen several "egg" shaped leeboards (the traditional ones) that pivot at the upper end of the board. There's only one board on the boat, and I'm pretty sure it's permanently attached to one side. How does a board like that work when it's on the weather side? The upper end is attached through the pivot, but I thought pressing against the hull kept the board in place when it's on the lee side. I don't see how it avoids getting pulled away from the hull and damaging the pivot when the pressure on the board is away from the hull??
Old 01-07-2005, 05:31 PM
Rep: 66 Posts: 640
Skippy,
Go back and check again. I'm sure you'll find two leeboards. For the rest you're correct. The one on lee is pressed to the hull and kept in place. While going about the lee side is pulled up and the weatherside one is lowered.
Dutch Peter
Old 01-07-2005, 08:00 PM
Rep: 12 Posts: 568
Thanks Pete, that makes more sense.
These two have a bracket, but the brackets look very small to me:
http://www.cedarislandcanoes.com/inf...akesail&page=2 (there's a link to the bracket in the middle of the page).
http://www.enter.net/~skimmer/building/building.html
This one is egg-shaped, but now that I look more closely, there does appear to be another pivot inside the far hull wall.
http://ca.geocities.com/bmboats2002/Pages/leeboard.htm
Thanks a lot.
Old 01-08-2005, 07:04 AM
Rep: 66 Posts: 640
Skippy,
Size depends largely on the amount of sail carried and the amount of underwaterbody of the craft. Body above waterline can also play a factor.
On the egg-leeboard picture you can see the top of the leeboard just rise above the gunwhale. There are two!!
Did you know that in Holland there are vessels up to 35 mtrs sailing with leeboards?
It's very typical for Classic Dutch crafts (fishing and small trade).
Dutch Peter
Old 01-08-2005, 10:16 PM
Rep: 12 Posts: 568
Originally Posted by Dutch Peter
Size depends largely on the amount of sail...
The mounting brackets look small. Thanks for the info.
Wood Top For Boat Dallas_B_ Materials 8 06-20-2006 12:50 AM
Broke College Student Trying to build a Hard Top for an Express: Pleeeease Help me... searaytuna Fiberglass and Composite Boat Building 15 10-28-2005 03:56 AM
Top Hat with Carbon or E-Glass UD's Boa Boat Design 2 06-09-2004 07:49 AM
boats.com top 20 list Scott Sailboats 0 10-30-2001 05:47 PM
boats.com top 20 list Scott Powerboats 0 10-30-2001 05:44 PM
