  #31
Old 05-18-2010, 02:42 PM
Pompey Pompey is offline
Rep: 10 Posts: 16
Thanks for your help guys. Tried a few things since my last post. Club boom wouldn't work because of cabin but appreciate the principal. More sail up front (with a temporary genoa) improved things a bit. Then I tried raising the jib, just 12", to be clear of the cabin, using a strop... and bingo - she's right up into the wind where she should be. Although it wasn't obvious from the tell-tails, which are a fair way up the sail, I guess the turbulance and drag of the cabin were 'spoiling' the full power of the jib into the wind. Problem solved.
  #32
Old 05-25-2010, 12:17 PM
Rep: 10 Posts: 16
Follow up for anyone interested!
Seeing as so many of you contributed, I thought I would just post a follow up for anyone interested. This is the log from last Sunday when I sailed up Southampton Water. Goose-winging on the way up in a gentle south-easterly then tacking back into the wind against a small tide. As you can see, lifting the jib clear of the cabin has definitely made a difference. She's full of surprises and I'm starting to appreciate her again. Thanks for your contributions. Pompey
  #33
Old 05-25-2010, 12:28 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Very nice to read a success story where one simple change solved a problem. So many times, it's a matter of incremental changes here, there and everywhere, that eventually add up to a noticeable improvement--or not....
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Tendency to broach during beat or close reach Joakim Sailboats 18 10-30-2008 01:21 PM
Close Molding....... nastro Projects & Proposals 2 05-24-2008 07:51 AM
Close relation with Casting Çemberci Propulsion 0 05-03-2007 01:12 AM
True wind/apparent wind? pygmalion Boat Design 5 12-09-2004 06:52 AM
How close to the wind can a boat sail? tonyr Sailboats 13 06-13-2004 07:35 PM
