Old 02-26-2006, 11:39 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
tie bar for twin rudders
When using twin rudders, where the rudder post is tilted both forward a little and inwards, what is the normal procedure for installing a tie-bar between them?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 02-27-2006, 12:47 AM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
I found the easiest to fabricate is a u shaped joint with an axil threw the two sides and one down threw the centre. This allows up and down movement and rotation.This should align to any angle.
Old 02-27-2006, 01:38 PM
Rep: 696 Posts: 1,232
You can fabricate a universal joint as suggested by Bhnautica, or take the easy way out with a pair of Heim joints. These have a spherical element that rotates and tilts. They are available at your local bearing supply distributor. They are available in stainless too.
Old 02-27-2006, 07:55 PM
Ah yes - but that's not really the problem - if there is one at all...
If one rudder is actuated (hydraulic steering) and the other is simply turned by means of the tie-bar, then one rudder will turn more than the other, given that they the rudder posts are angled both in and forwards....
Will
www.imaginocean.net
Old 02-27-2006, 10:07 PM
Rep: 499 Posts: 489
Sorry Willallison I misunderstood the question. Yes there is a small difference in the angle between the two rudders. This difference would depend on the distance the tie-bar was from the rotation point, the angle of the rudders to the vertical. Take for example two rudders at about 15 degrees to the vertical, 2 metres apart, with say the tie-bar about 650mm from the rotation point. Angle the rudders over to 30 degrees; the difference would be just less than 1 degree.
Twin engine, twin rudder and doors on a sailing yacht Arvy Boat Design 9 10-23-2005 11:20 PM
Twin Rudders. whaletail38 Sailboats 3 02-04-2005 04:04 PM
Load carrying “Targa Bar” skedadle Fiberglass and Composite Boat Building 1 10-25-2004 04:09 AM
Twin Rudders vs Twin Keels mimmosan Boat Design 2 09-22-2003 07:31 PM
Power tie breaker duluthboats Option One 1 07-02-2002 12:38 PM
