Old 07-31-2011, 03:54 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
"seal it all down with FixTech (Polyurethene)"....no, epoxy will NOT stick to it.
Old 07-31-2011, 08:26 PM
Harold Anderson Harold Anderson is offline
Rep: 10 Posts: 14
I am not familiar with Fix Tech, Polyeurethane. Who makes it? Will it hold the backing plate and sea cock over the thru-hull hole if the thru hull is sheared? Sorry for all the questions but I only want to do this once and need piece of mind when I install these new marelon thru hulls.
Old 07-31-2011, 09:05 PM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,870
Eurothane is a product made by a few people,-- maybe sikoflex is more familiar.
Is you boat solid glass or balsa core construction, if it is a core then it is far more involved than this, but not difficult just a different procedure.
Old 07-31-2011, 09:26 PM
Rep: 10 Posts: 14
Sikoflex is a name I am familiar with. My boat is solid glass no core. Thanks
Old 08-01-2011, 10:35 AM
Frosty's Avatar
Right then,-- now we got the info...
If you have a bit of fibre glass sheet I would cut a six inch square and cut a hole to the fitting then cut the hull and sika it all together. This just strengthens the hull where the fitting is.
If your fitting a cock to the fitting thread check to see if the cock and handle will align the way you want it and mark the fitting accordingly to get it in the right place.
How many hulls ? PsiPhi Stability 21 11-07-2010 02:27 PM
used hulls madmike7221 Open Discussion: All Things Boats & Boating 1 07-14-2010 09:12 PM
Raw intakes, exhaust and other thru hulls on Fiberglass Hulls ChrisN67 Boat Design 7 12-27-2008 12:40 PM
Who knows hulls b.hernackiAgte. Open Discussion: All Things Boats & Boating 0 09-14-2005 11:49 PM
Four hulls better than two? Wynand N Boat Design 5 03-12-2005 02:46 AM
