Old 09-12-2002, 10:31 PM
thru-hull fittings
Does anyone have experience with Delrin thru-hull fittings. I understand the benefits of a non- corrosive fitting, what are the negatives? Are they superior to a well made and cared for bronze counterpart?
Old 09-13-2002, 05:39 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Hi Guest and Welcome,
Can I ask whats the hull made of?.....
Paul
Old 09-13-2002, 07:04 PM
thru-hull fittings
Hello Polarityand thanks for the welcome, the hull is fiberglass.
Old 09-14-2002, 10:33 AM
Rep: 148 Posts: 480
OK well the normal arguement against them is fire - but in a grp hull that's irrelevant!
I would say imagine you have the boards up and you are moving your storm anchor when you accidentaly drop it on the fitting. If you are happy with that scenario then you have found a solid and well made product - use it!
Otherwise a "well made and cared for bronze counterpart" will do the job admirably. - You dont really have much of a galvanic/electrolisis problem in a grp hull (as long a you don't bond the through hulll to anything) as there is no circuit.- it is isolated by the hull and plastic tube - But there are 2 schools of thought on that - the other one says what about the water in the pipe as a conductor - and I dont want to get into that argument!
The thing to watch out for in any existing bronze fitting is a pinkish tint to the metal - de-zincification - you may find they have the strength and watertightness of a sponge cake!
Paul
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
