Not quite. If the span is the same, the induced drag will be the same. Induced drag does not depend on aspect ratio. The confusion comes because the induced drag coefficient depends on aspect ratio. But when you calculate the dimensional drag (in N or lb), aspect ratio disappears and is replaced by the square of the span. It turns out aspect ratio really should be regarded as the nondimensional form of span-squared instead of focusing on slenderness. But you're spot on with reducing the profile drag by reducing the wetted area.
| I don't know ... Looking at the original criteria we have a foil that is strongly limited in span. To my mind getting enough lift may be a problem. Think rough water and lots of drag from not being able to reduce the sailplan. Is there much weed in the area? If there is, a less critical foil section may come out on top. I would be going with the thickest foil possible and would not be overlooking the NACA00xx sections either. The general rule is design for the lift - THEN look for means of reducing the drag. Or am I missing something that is too subtle for me to grasp. Best wishes to all Michael Storer
__________________ my boat pages |
| Modify laminar flow for increased performance? | JonathanCole | Boat Design | 3 | 08-19-2005 06:13 PM |
| Matching Mast Sections | phillip | Metal Boat Building | 5 | 04-22-2005 07:54 PM |
| Wing sections? | tizbonbon | Sailboats | 10 | 02-21-2005 09:27 PM |
| Float design under laminar conditions | Nidhi | Boat Design | 5 | 10-05-2004 12:35 AM |
| Youngs Laminar Bodies | sorenfdk | Boat Design | 3 | 01-17-2004 06:04 AM |
