Old 10-10-2006, 05:15 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
If you want to do a simple estimate, which the subject line implies, then a prop of similar diameter to the bulb will do quite well.
If you want to get fancier (which your text implies), then I would try all of the methods above - but that's not "estimating" in my book.
Too high-falutin' fer me.
Steve
Old 10-11-2006, 12:25 AM
Dan S Dan S is offline
Rep: 23 Posts: 93
Thanks, for the help everyone, attached is the foil that I will be using. After I finish this project, I need to go back and get a more in-depth knowledge of fluid dynamics. I’m pretty sure I could write, a 3d solver (it’s what I went to school for “computational physics”), if I had a better understanding of the problem.
Happy Sailing
-Dan S.
Old 10-11-2006, 02:55 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
3D solvers are not easy to write, and considering the number available (do a search on the web) there isn't a huge amount of point. Find one that is already written and use that.
If you want to use a CFD method to analyse the bulb, you will need to do the calculation with the fin attached. The flow pattern with/without the fin will be totally different.
You can also achieve lower drag by making the bulb non-axis-symmetric. Have a look around a marina at the racing yachts to see what I mean. That will need 3D CFD to analyse.
Good Luck,
Tim B.
Old 10-11-2006, 04:01 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Maybe another question could be, what profile do you recommend for a bulb with circular sections? We used a naca 0018. I see that many use a profile with maximum thickness further aft.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 10-11-2006, 09:23 AM
Rep: 1758 Posts: 1,561
I concur with Raggi's point; I think the bulb you showed needs to be fuller aft. It looks like you used an inviscid soloution.
i wanna ask about shipBuilding estimating cost please a3g1s Boat Design 7 04-21-2006 09:23 PM
Catamaran Design - estimating speed from weight, rpm and thrust springer Boat Design 2 11-05-2005 02:33 PM
estimating the resistance of a submarine amirhosein Boat Design 0 04-25-2005 01:59 AM
estimating displacement dionysis Sailboats 2 02-15-2003 11:56 PM
speed and prop operation theories curtis73 Powerboats 7 03-23-2002 06:27 PM
