  #31
Old 11-22-2004, 10:04 AM
webbwash webbwash is offline
Rep: 10 Posts: 35
Two additional thoughts come to mind --
1. If you are set on the additional "ground plate" follow JeHardiman's advise and make it come shy of the leading edge of the keel, you want to keep the kelp from becoming entangled.
2. If you don't want to improve your AR, Aspect Ratio, hence improve efficiency to windward, then the addition of "winglets" ala the twelve meters and some of the Hunter Boats, is viable. You have to do the displacement/wetted surface/performance design spiral a couple of times around to find out that the improvement is not $$$$$. Change the rig to a "modern" carbon fiber, get improved sails, and smooth bottom may add better performance than messing with the keel.
There is only so much you can do to increase the performance of cruising boat -- have you thought about adding a scoop which would add a nice swim platform and some waterline length.
Every change that you make - including taking out the interior and the extra bathtub and replacing them with lightweight joinery or nothing at all will "improve the performance" but at what cost to the comfort of cruising and the enjoyment of just being on the water.
  #32
Old 04-28-2005, 05:21 AM
RDKinard RDKinard is offline
Rep: 10 Posts: 20
Drag from 1-2" skeg to rudder gap ??
Guys,
Part of our problem may be the 1-2" gap (along the tangent streamline) between the skeg and rudder, adding drag (see attached photo). Looks like the builder located the rudder pivot about 3/4" aft of what the architect wanted, leaving a large sucking gap between the two.
The marina suggested adding Teflon fins between the skeg and rudder which fill the gap and flex with rudder angle. The Navy 44's all have such fins added.
Does this make more sense to reduce drag than a foil on the bottom of the keel?
Captain Rich
Teardrop End Plate On NACA Flat Bottomed Fin Keel ??-sabrinasskegruddergap.jpg
  #33
Old 04-28-2005, 08:15 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
Originally Posted by RDKinard
The marina suggested adding Teflon fins between the skeg and rudder which fill the gap and flex with rudder angle ... Does this make more sense to reduce drag than a foil on the bottom of the keel?
Short answer: Yes.
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
  #34
Old 01-12-2006, 03:13 PM
prancer prancer is offline
Rep: 10 Posts: 2
What happened?
So, did you ever try adding an end plate to the keel, and if so, how much quicker was the boat?
  #35
Old 01-14-2006, 12:40 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Marco Trucchi had posted one of the few really decent papers on the fluid mechanics of keels.
This figure is particularly relevant to this thread:
It shows that if you want to improve the performance of your keel, you're far better off tacking the wing on as a straight extension of the keel than you are using it as a winglet.
Wings only make sense if there is some non-hydrodynamic constraint on the depth of the keel, such as class rules or the depth of the water.
Tom Speer
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 08:15 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 07:55 PM
Steel plate Thickness LowcountryData Sailboats 29 11-30-2004 03:17 PM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
Altering shoal draft keel? CaptK Boat Design 8 10-06-2003 09:54 AM
