Old 09-08-2010, 02:14 PM
BobBill's Avatar
BobBill BobBill is offline
Rep: 104 Posts: 379
Location: Minnesotan wakes up daily, a good start, snow or not, in Gingerville.
Tape to Use with Epoxy Resin
What is a good tape to use with epoxy that will release easily when pulled off?
Say where fasteners hole or errant through cut saw slits may exist.
Leave a place better. Congress is the enemy!
"All ya gotta know!" Dog. Winona.
Old 09-08-2010, 02:47 PM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
For what purpose? I don't quite understand what you want the tape to do.
Old 09-08-2010, 03:51 PM
Rep: 3125 Posts: 9,403
Plastic packaging tape is excellent for this, duct tape is a favorite by some as is regular masking tape, though I've had both duct and masking tape stick to cured goo fairly well in the past so I use plastic packaging tape exclusively. I use the thick stuff most of the time, but the thin stuff work good too, it's just weaker.
All these tapes need to be pulled pretty much as soon as you can, because the longer you leave them in place, the more likely the glue will transfer. Solvents can handle the glue, but it's an added pain in the ass that's not necessary if you remove the tape promptly.
Old 09-08-2010, 07:53 PM
BobBill's Avatar
Rep: 104 Posts: 379
Tape to use as release with Epoxy Project...
Thanks Par.
I had no clue. Thought I needed to grease strips with wax etc to make it work. Makes project so much easier...mercie!
Old 09-08-2010, 09:47 PM
Send me a beer when you get a chance . . .
epoxy resin garrick Materials 1 01-16-2009 02:48 PM
Epoxy resin bulk-head Materials 11 01-05-2008 03:22 PM
New Teak Deck Caulking: Tape or No Tape? Scott Carter Wooden Boat Building and Restoration 5 07-10-2007 01:50 AM
Epoxy Resin eurotk1 Fiberglass and Composite Boat Building 6 08-27-2004 03:50 PM
epoxy resin? jstephen Wooden Boat Building and Restoration 5 02-23-2004 07:32 PM
