| Re: Tandem keel Quote:
Wings don't get rid of the trailing vortices, they just move them laterally away from the rest of the keel so that they don't have as great an effect. But for the same addition of wetted area, you can get a greater gain by making the wing an extension of the keel than you can by mounting the same surface as a wing. Wings only make sense if there is some constraint on the depth of the keel. The constraint could come from rating rules, or from the need to sail in shoal waters, or even for easier carriage on a trailer. Wings may also be a more productive way of packaging the volume of ballast. But for pure hydrodynamic efficiency, go for span every time. Quote:
It's always interesting to ask, "So, may I see your data?" If you get a lot of mumbling and handwaving and statements like, "Well, it's all due to the collateral thermal end-plate effect, and you really can't compare it with a conventional configuration," then I'd be inclined to walk away. And if he claims to have discovered some revolutionary new physics then I'd not walk away, I'd run. But if he says, "Here are some estimates of a comparable conventional configuration compared with published test data so you can see how well the estimation technique works, here are the estimates of the new configuration showing the improved performance, and here are our test data on the new keel validating the predicted performance," then I'd be inclined to plunk my money down. It's perfectly reasonable to expect a minimum of two out of these three.
| If tandem keel really works spectacular... All of IACC yachts will have one... ![]() I don't like the tandem keel posted on page 1... i think for these boat, will work better a semi-long keel... |
| THe Collins keel seems to work really well. tRodger Martin and I put one on a 43' cruiser/racer (Quadrille) for a client who wanted low draft and high performance. There was no appreciable down-side to the thing, unless you like being bounced around on the mooring ;-) Performance was just right, and it had the added benefit that at launching time one of the yard crew rode it down "Dr. Strangelove" style Steve |
| Yipster - sitting between the two foils, on the bulb, waving a baseball hat ;-) |
| well, i'm dizzy from trying [unsuccessfully] to figure out the numbers, but i seem to remember an america's cup 12 meter that had twin keels. wasn't the designer or owner named blackaller, or something similar? it seems that boat pointed high but the widely separated keels caused some handling problems. america's cup rules only allowed for two underwater appendages so the keels had to act as rudders, as well. how about a trim tab on an existing keel design? how efficient is that addition? |
Somebody sailed a boat with trim tab? Or design, build... ![]() |
| If anyone would like to comment on my keel idea, check it out at http://boatdesign.net/forums/showthr...5&pagenumber=2 BTW the first tandem keel I'm aware of was on a boat designed by Art Paine, identical twin brother of Chuck Paine and built in the late 1960s (or perhaps 1970) to compete with the Soling and the Etchells to be the new 3 man olympic keelboat. Art built the boat with the assistance of a young fella named Eric Goetz, but they didn't have it ready in time for the competition (Eric's been lothe to miss a deadline since!). Last edited by Stephen Ditmore : 12-05-2003 at 07:27 PM. |
| Recently posted on "Hull Is Slower Without The Keel": I sail a micro-cruiser. It is a Sandpiper 565, 18'6" LOA with a 15'0" LWL. This little boat has 300 lbs of lead ballast in a keel that raises vertically into the cabin table. When completely retracted, the bottom of the keel is flush with the bottom of the hull. Recently, while sailing straight downwind wing-on-wing, the keel was cranked up to reduce wetted surface and to reduce drag. To our amazement, the boat speed appeared to decrease! So the experiment was repeated a 2nd time and the result was inconclusive. But, the speed did not increase as expected. The experiment was later repeated by a different boat using its outboard motor. Again, there was no detectable change in speed. The boat speed was being measured using GPS with resolution to 0.1 knot. The sailing experiment was conducted at about 2.8 - 3.1 knots. The motoring experiment was conducted at 4.7 - 4.8 knots. Hull speed is estimated at 5.3 - 5.7 knots. Is there an explanation why withdrawing the keel should not increase the boat speed? Especially while travelling below hull speed? Does the keel somehow change the boat's wave-making ability to give the illusion of a longer boat? Does the appendage sticking out the bottom of the hull somehow mimic the winglet on a bulb keel? Does it provide less drag despite its increased wetted and frontal areas? Quote:
This old post by Tom Speer may include some revelation about my retracting keel. Tom's logic held the span constant. In my Sandpiper example, the span and the area are both changing - each countering the advantage of the other. Reducing the span causes a marginal increase in drag but reducing the wetted area causes a marginal decrease in drag. So, ain't that cool ? |
#25
| Harmony is a French big prduction sailboat manufacturer directed and owned by Mr Poncin, the man that was for many years the Director of Dufour yachts (that he has sold to the Italians some years ago). The Harmony are on the rise and that in a country that is the home of Beneteau, Jeanneau and Dufour (that made boats for the same market segment) is quite an accomplishment, considering that Harmony has no tradition and is a completely new company. One of the most distinctive features of the Harmony is the tandem Keel that is offered as an option. The Tandem is the keel choice for cruisers and has proven very well. Harmonies are designed by Mavrikios and Mortain and they say about the tandem keels on the Harmonys: “Those looking for small draughts will be delighted to know that cast-iron tandem keels …offer almost the same sail stiffness and the same ability to go close winded as lead keels with far deeper bulbs”. http://www.harmony-yachts.com/public...%20Harmony.pdf http://www.eurobateaux.com/accueilpy.htm http://www.mortain-mavrikios.com/ They also do them for the Etaps. Etap says about them: "After thorough investigation and numerous tests, ETAP Yachting N.V. is pleased to introduce its ETAP tandem keel. The most important advantages of this keel are the excellent sailing qualities at a considerably reduced draft. This new design is the result of a co-operation with the architects' bureau Mortain-Mavrikios. The two most important features to reduce drift, are the size of the lateral plan and its efficiency. The efficiency is defined by the proportion between the depth of the keel and the length. Also a wing section is a classic aid to improve the efficiency. For a strong reduction of the draft neither a wing keel or a bulb keel were sufficient. The solution was found in placing two shorter keels behind one another, linked by a wing-bulb profile : the ETAP tandem keel. The ETAP tandem keel gives a better aspect ratio, thus generating more lift. In addition to increased stability, the wing-bulb also provides better hydrodynamic characteristics. " http://www.etapyachting.com/index.php?pageID=37 |
#26
| n+1 > n just turned into EMO's bad dream? Say it ain't so! Must be those pesky details Tom's mentioning. I must admit, though, when those slotted windsurfer skegs spun out, they REALLY spun out. Usually when goofyfooting on the starboard tack. Yikes. Exit, stage L, right ankle (and L hemisphere) throbbing, Paul |
#27
Yes, of course the presence of an appendage alters the hull-generated wave pattern, whether this is in a positive or negative manner depends on the length/speed and number of wave crests between bow and stern. Might I suggest that your initial findings are a little on the crude side, but as you found out, in most cases the difference in viscous resistance between centerboard down/retracted is marginal when compared to the wetted surface and wave-making capacity of the hull. Tspeer makes some very good points, and he is entirely correct, but two and three surface interactions can be very difficult to predict - possibly for the reason that obvious definitions in the aerospace industry become muddied rather quickly when applied to sailing yachts. For example, in the above example the aspect ratio term drops out entirely because he is defining AR as b^2 over S, where S is the total keel area (more accurately could be total underwater planform area). This is valid for closely spaced foils but if stagger increases to around 3 or 4 (distance normalized against chord length) then considering the foils separately and each having their own AR (b^2/S) would be valid. This is what the America's Cup yachts were doing, although they were hampered by the two movable appendage rule, which is something a tandem can really use to advantage... |
#28
| Naval Ark: Great explanation. Even I comprehend. Yes, the wetted surface of the keel is only a fraction of the hull's wetted surface. And it is the hull that is making waves. Thanks for the insight. |
| Lifting Keel | JHuberman | Boat Design | 19 | 06-26-2007 02:11 PM |
| Compromises - Ballast keel? | Mohan Pakkurti | Wooden Boat Building and Restoration | 7 | 11-14-2005 06:53 AM |
| Cheap And Simple Hi-Tech Keel? | Wynand N | Boat Design | 9 | 05-24-2005 07:55 PM |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
| Altering shoal draft keel? | CaptK | Boat Design | 8 | 10-06-2003 09:54 AM |
