Old 03-06-2009, 04:26 PM
chabrenas's Avatar
chabrenas chabrenas is offline
Mike K-H
Rep: 10 Posts: 100
Synthetic fibre rigging
I know the Moths all use it, but can anyone tell me a bit more about Aramid and PBO fibre rigging on bigger boats?
- has it been in use long enough to judge how durable it is compared to traditional materials like stainless rod or wire?
- some synthetic fibre rigging has crimped/swaged end fittings, and some is custom-wound to length with end fittings integrated. Anyone have experience of the differences in characteristics?
Mike K-H
http://www.newfreebooters.com
Old 03-06-2009, 04:39 PM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
Taking my opinions with a grain of salt (I am currently using kevlar on one boat & wire on others), I've heard the PBO rigging is light, strong and susceptible to UV damage if the covers are breached. There have been lengthy discussions on Sailing Anarchy in the Dinghy, Gear and Sailing Forums. There were also concerns with abrasion damage.
I've also read that getting the lengths set at the factory with factory fittings is the only way to go.
This is all hearsay, your mileage may vary.
Bill
Old 03-06-2009, 05:06 PM
Rep: 593 Posts: 2,054
Click here to add me to your ignore list
Brilliant, Mate
Old 03-06-2009, 07:20 PM
PortTacker PortTacker is offline
Rep: 25 Posts: 77
Yes, synthetic rigging has indeed been in use long enough, on everything from trailerables to high tech offshore racing weapons to world cruisers, to prove itself. Every racing yacht with any pedigree to speak has had it for years, it's on all the Vendee, Volvo, round-the-world record tris, etc. It's found on many small boat too, many Corsair trimarans have been fitted with synthetics. Most any new boat with a serious pretense of performance will be spec'd with it.
Yes indeed it is viable. It works, and works very well.
Yes, it is different than wire, and has to be rigged and treated differently. Yes, it has it's pros and cons.
A few of the not-inconsiderable cons for the vast majority of us is that it's at least twice the cost of wire, does not last as long as wire, and you MUST do certain maintenance to it, or it doesn't last long at all. With proper care and feeding and a budget for timely replacement, it's great stuff. But only if you NEED the weight savings, in my opinion. It's really not for everybody.
Old 03-07-2009, 12:25 AM
jmolan jmolan is offline
Rep: 65 Posts: 65
I recently re rigged my 34' Searunner Trimaran. I used Dunex Dux 12 strand SK-75 which has been heat stretched. I have a few links you can look at a lot of details. It will make wire obsolete, just watch. Normally, you do not get leaps like this in the sailing world that are not super expensive. Using Dynex Dux and fittings from Colligo Marine, my rig came in LESS than a similar SS rig. And at least 35lbs. lighter. Doit yourself, lighter, stronger, and less money. No worries about swages, corrosion, fatigue. etc.
http://www.cruisersforum.com/forums/...ner-22345.html
http://www.cruisersforum.com/forums/...ing-10078.html
http://www.cruisersforum.com/forums/...ing-18184.html
http://smalltrimarans.com/blog/?p=800
Old 03-11-2009, 04:53 PM
Rep: 25 Posts: 77
When it first became available it was more than 10x the cost of stainless, and not very durable and not entirely reliable. That was many years ago. IN fact only a couple of years ago it was still many times the cost of stainless.
But I agree, I think it will become normal one day and stainless antiquated.
Synthetic rigging properties? Gashmore Sailboats 38 02-13-2011 10:36 AM
Synthetic teak deck dmc Materials 74 08-07-2010 06:50 PM
Synthetic Searunner San Carlos Sonora jmolan Multihulls 5 01-19-2009 03:15 PM
Fibre over steel yarrick88 Fiberglass and Composite Boat Building 0 06-10-2007 07:56 AM
Synthetic Rigging mojounwin Sailboats 3 02-18-2006 08:48 PM
