If I remember correctly, that board weighs in at around 900 pounds and is cast iron. If this is the hull that has the 6" stubby fin under the belly where the slot is, the pin is in the forward lower corner. If it's the hull where the slot is directly in the belly (no protrusion on the bottom) then the pin is inside the cabin. You will see some distortion around the area where the pin lives. This may be wax, tar, foam, who knows, hack it out until you find the end of the pin. After a little grinding it may make itself obvious with rust stains and flakes, the 'glass in the area may also show signs of delaminating. Feel around with a small magnet, this will get you close, then gas up the grinder.
The board will need to be supported with the strength to man handle 900 pounds of iron out of the slot. Not an easy thing for the backyard DIY'er, but it can be done. You don't want it to fall, because more often then not, the thing will get it's half a ton *** jammed in the slot. Think about using slings rigged around the boat. Personally I use a tractor with a bucket, though it's usually replaced with a rake. The boat needs to be well supported, stands chained and weighted down (I prefer cradles). You can easily knock the boat off the stands trying to wiggle the board out, it weights near as much as the boat and you'll likely be using a bit of force.
To get the pivot pin out, once it's been found and exposed, you relieve the weight on the pin by lifting the board and it should slide right out, in a perfect world. In reality it will need to be drilled, beat on, cussed and generally talked it's way out of the hole (yes, you can bet it'll go kicking a screaming)
After you've passed beer around to all involved, you should consider how to get things back in order. If the pin rode in a bushing, replace it, if not, drill for a bronze one, sized to fit a new pin. Clean the board (sandblast) and give it a coating of epoxy, maybe a strip of 'glass down it's leading edge to protect the coating, if you want (you don't want to have to do this again) If, possible see if you can engineer a way to get a zerk fitting in the bushing, so you can grease the pin every so often. Remember to seal the pivot location up again in a way that will not let the pin get glued with the sealing up process (wax or tar or my favorite clear plastic box tape) use epoxy for the glass work, it's stronger and doesn't stick to the tape.
Invite lots of big friends over when you do this, they may come in handy. It's nice to have friends around to laugh at you when you screw something up or bang your head. You can put them to work dragging the beast (trust me this is what you'll be calling it once you do get it out) someplace meaningless just to get back at them for laughing when you banged your head.
Good Luck,
