Old 02-19-2008, 02:23 AM
nick125 nick125 is offline
Rep: 10 Posts: 5
surface finnish
does anyone know of any really good cutters/ polishes for getting a really fast surface finnish?
Old 02-19-2008, 10:48 AM
Rep: 3125 Posts: 9,403
All finishes are a matter of prep, not chemistry. Cutters and polishes are nothing more then abrasives (very fine of course) intended to remove small imperfections in the surface. They will not make a smooth surface, but will knock down very small high spots, brush marks, spray gun stipple and small scratches or other defects left over from the smoothing process.
If you have a smooth surface and want to make it slippery, then Teflon based waxes can help, which can be burnished every so often to keep them slick. Some paints suggest their Teflon additives will do the same thing.
I've found elbow grease and fresh wax, applied carefully is the slickest bottom coating, but the bottom has to be really fair and smooth for the full benefit to be realized.
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
Surface continuity Smircio Software 16 06-10-2006 10:33 AM
Solid Surface. artisan Materials 0 11-21-2005 11:35 AM
rudder surface JLP Sailboats 4 09-06-2005 08:10 PM
3D Surface Help lazza Software 1 06-05-2005 01:46 PM
