| Support for swing keel in drydock I bought a Chrysler 26 swing keel and want to transport it to my backyard for painting and a bottom job. I also want to service the swing keel. My fin keel boats had the keel resting on a solid surface with supports for the hull. How do I support the boat 3 feet off the ground with the keel able to swing free. Don K. |
| Hi Don, I just dropped the keel out of an old MacGregor 22. We simply lifted the boat with slings and placed it on five tripod-type boat stands. Four of the stands had flat, carpeted, pads and the fifth had a V for the stem. They were safety chained together. We had a full five feet under the keel before we lowered it, and it was steady as a rock... which isn't to say we loitered underneath it... but it worked well. Most yards rent them if you are on their hard. I sail with two other guys and we decided to buy a set and share them. I think they were about $100 each. To ease handling woes, we built a plywood and timber holding fixture to capture the keel. It proved to be even more useful when it came time to re-install the keel... three guys aren't much of a match for a six hundred pound hunk of steel... |
| here ya go... |
| oops.... don't read the "do's & don'ts" section... the first thing Brownell Boat Stands, Inc. tells you NOT to do is suspend the vessel in mid-air. where's my sword...? |
| Lifting Keel | JHuberman | Boat Design | 19 | 06-26-2007 03:11 PM |
| Cheap And Simple Hi-Tech Keel? | Wynand N | Boat Design | 9 | 05-24-2005 08:55 PM |
| Swapping the keel on a British Hunter Sonata | BrianBrowne | Sailboats | 1 | 11-10-2004 05:18 PM |
| Altering shoal draft keel? | CaptK | Boat Design | 8 | 10-06-2003 10:54 AM |
