Old 11-20-2006, 02:13 AM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
Suck or Blow?
Is there a "best practice" for mounting bilge ventilation fans? Should the fan be close to the engine compartment and blow through a long duct to the outlet or should the fan be mounted close to the outlet and suck through a long duct?
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 11-20-2006, 06:39 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
location
Since all the "bad" fumes the fan is supposed to disperse are low it makes more sense to mount the fan high near the exit and suck through a long tube. Keeps any errant sparks from the fan motor from igniting the fumes you are trying to get rid of.
Old 11-20-2006, 11:14 PM
RHough's Avatar
Retro Dude
Fair enough.
The reason I ask is that most fans are better at blowing than sucking
Thanks for the reply.
- Thomas A. Edison
Old 11-20-2006, 11:53 PM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,874
Not only that but if you blow the engine comartment all the smells and fumes will not necceserily go out the hole you want . it will also go through all the little holes and feed pipes spreading fumes throught the boat.
Old 11-24-2006, 02:31 PM
messabout messabout is online now
Rep: 749 Posts: 1,314
Squirrel cage fans suck pretty good. Centrifugal paddle fans suck even better...Think vacuum cleaners. Conventional bladed fans do not pull air in as well as the other types unless they are tightly shrouded. Think Kort nozzle.
Old 11-25-2006, 02:18 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Ought to suck about as much as it blows, you know, conservation of mass and all that pesky stuff.
Old 11-25-2006, 04:30 AM
Rep: 756 Posts: 3,328
With a std 4 inch engine room blower I'm not sure you could measure the difference, but blowing is more efficent.
However mounting any electrics as far above any possible water is the most rational.
FAST FRED
smart blow-up keyholder € 6.- yipster Open Discussion: All Things Boats & Boating 58 11-30-2005 01:14 PM
