Old 08-29-2009, 06:09 AM
oatsandbeans oatsandbeans is offline
Rep: 10 Posts: 2
Stern Down Trim Problem
I have a 44" sailboat that has a distinct stern down trim problem, this is only apparent when sailing, not at rest, and seems to get worse the faster the boat goes I was sailing a few days ago on a reach ( not much heel) at 10-14 knots and it was really bad. What should I do? Forget about it ( the boat sails really well despite this), look at a keel mod. ( expensive?), or some sort of transom mod (another 12" fairing?) ( not so expensive).
Any comments would be appreciated
Old 08-30-2009, 06:07 AM
Rep: 2891 Posts: 8,789
Without knowing what you have, how it's equipped, etc. it would be very difficult to guess at you question.
As a rule, the faster a sailboat goes, the more the stern settles onto the troth created by it's wave train as it passes through the water. The angle isn't objectionable on most boats.
Old 08-30-2009, 10:33 AM
Rep: 10 Posts: 2
Thanks for the input. Interesting about the comment on sinking down into the wave pattern at speed sounds spot on. The boat is a "performance cruiser" I'd rather not say the make and design as I may want to sell it and don't want any bad PR about it.
I don't know enough about yacht design to know if it is a real problem or not, but it makes a lot of noise and lots of turbulence and the transom seems to have sunk 6-9". I was wondering about putting a scoop on the stern to try to fair in the back end when it is down in the water. Possibly even making a swim platform out of it to disguise it.
Old 08-30-2009, 06:37 PM
I wouldn't have a clue how to address the issue without a year, make and model. If it's a model related issue, it likely all yachts of this particular mold have the same issue, so yours in nothing new. If it's something odd, because other examples of this model don't display this behavior, then not knowing what we're working with isn't very helpful.
I have a car, it runs fairly well and it's performance oriented, but it seems to skid excessively in the corners, can you help me . . .
Old 08-31-2009, 02:34 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,728
It is made by one of the US big three...
There...See...question answered to a tee.
in all fairness PAR is correct...we have to know which boat it is in order to determine if it is a singular problem exclusive to your boat or a design flaw which is/has already been noted in the design. You can do a bit of detective work on Google by punching in the design and playing with various versions of "Problems With" or "Design Flaws"...if you get hits well then...
If not then we will need further info as to construction (could be the core is soaked and the boat is extra heavy), or added equipment (big heavy diesel engine as opposed to light gas one) etc.
Steve
Old 08-31-2009, 03:40 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Or just read the last Masthead to find out what a real Stern Down Trim Problem looks like
Issue 11 of Westlawn's free quarterly journal, The Masthead, has just been released
Old 09-04-2009, 07:10 AM
Munter Munter is offline
Amateur
Rep: 100 Posts: 222
To give you an example of how other boats behave - at speed, the transom that you see elevated well out of the water in this picture has water flowing right up to the edge of the transom.
Cole 43 Rumrunner II - An Australian classic
My home efficiency/renovation blog
trim problem phil74 Propulsion 4 08-29-2007 04:57 PM
Porpoise/Possible Trim Tab Problem hrdcor32 Stability 11 03-29-2007 06:39 PM
Trim gauge problem thebassn8tr Powerboats 0 09-29-2006 08:39 PM
I/O Trim Problem, please help. In The Zone Powerboats 3 08-08-2005 02:14 PM
trim problem with boat I just bought, please help jetchris Powerboats 6 06-03-2005 01:46 AM
