Old 04-10-2006, 10:25 PM
Buc Buc is offline
Rep: 10 Posts: 37
Yes, you can certainly build a wood box mast. It's how masts were built for years. The box will be stronger than a solid mast of the same dimensions and, obviously, mugh lighter. Fiberglassing isn't really necessary, though it would reduce maintenance somewhat. It would also increase the weight. As the glass is primarily for protection, use as few layers as possible; one would be fine.
As for titanium masts on racing boats, I made reference earlier to Weatherly's mast with the upper third made of Ti. Its use was outlawed by the IOR for cost reasons, but Weatherly's mast was grandfathered when she went from being an America's Cup 12-meter to racing in the Pacific Northwest.
(I remember helping the IOR measurer drag the main back to a position aft of the mast for the flotation measurements. It was a two-ply dacron sail and too heavy for both of us. We got it to the front side of the spar and called it close enough. That would have been in about 1972-73.)
Old 04-11-2006, 03:53 AM
gypsiemarine gypsiemarine is offline
Gypsie Marine
Rep: 10 Posts: 6
Randall Gypsie Marine
Mate, go down to the marina and have a look at all the masts. 95% aluminium and 5% wood. There is a reason for this.
Old 04-11-2006, 11:13 AM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
Yup, that reason is extruded aluminium, resulting in easier mass production
Old 05-31-2006, 11:11 AM
CORMERAN CORMERAN is offline
Rep: 13 Posts: 65
To TUREDOGAN:
The Designer is on the right track - as far as I am concerned.
If wood came out of a lab. it would be called a "wonder" material.
It will endure many more flexing cycles - than most metals.
- The amount of fiberglass is not the first concern.
- Consider that: - fiberglass resin is POROUS.
- Whereas EPOXY is not.
- Also the glass does not have as much fatigue resistance as the woods
preferred to make masts. So - long term it's not really adding much strength.
- To me, the main function of the fiberglass, is to help build up a thick
layer of epoxy. Which is doing the most work in maintaining the
longevity of said mast.
- Also, the glass gives abrasion resistance.
However, be warned.
Making a mast requires diligence and skill. A small flaw has generaly,much greater consequences - than a similer error in the construction of the boat
it's self.
There are good reasons why marinas are filled with boats with
aluminum masts. It's really a challange to do as good a job as the professionals.
Old 06-04-2006, 07:16 PM
glenville glenville is offline
Rep: 10 Posts: 8
mast
My brother recently built a mast for a 34 ft. sailboat using layers
of fiberglass outside a mold. Its not been sailing yet but seems
plenty strong and relatively light. He can sit on the 40 ft mast when its
sitting on workbenchs at the ends!
I'm finishing a Roberts 31 and have a 47 ft alum. mast I'd like to cut down
to size but think it might be to heavy in the end. It's aprox 6x8 in.. Anyone
have any thoughts on cutting shorter an aluminum mast?
mark
Old 06-05-2006, 04:28 AM
Rep: 756 Posts: 3,328
Anyone
No problem although you will need to relocate the spreaders for the new overall hight, as well as any lower shroud or inner forestay mounts.
No big deal. The slightly heavier mast section may even give a better ride than a super lightweight mast .
FAST FRED
Old 06-05-2006, 12:01 PM
Rep: 13 Posts: 65
To GLENVILLE:
Re: Fiberglass
Yes, one can make a case for fiberglass masts.
They are actually very common.
Although, many people will not have noticed, as they are covered up
by the sleeve of a WINDSURFER'S sail.
However, please note:
Technicaly, the top of the line, windsurfer mast is very sophisticated.
It is vacum bagged - over a steel mold - and cured by hot steam being
injected INSIDE, said mold.
The resin often used is: air craft grade, epoxy.
If memory serves, the carbon fiber masts made this way, have 18 layers of carbon, within only a 1/4 " of wall thickness !
So dense, that if you drop one on the shop floor - it will a make ringing sound
- just like metal will. - And one suspects, will also transmit electricity.
Cutting down a mast - moves one, closer to an off - shore cruiser. A good thing, from a safety point of view, many will agree.
- In terms of you ending up with the new mast, being, in theory
- a bit more heavy than ideal.
I would, personaly, cut off - the heavier, bottom end of the mast. That is,
if the mast you have, is tapered to any significant degree.
What ever you do - it is advisable to make use of a Marine Engineer's
services.
As I've stated - small errors, in mast constuction - can have major consequences.
Stainless Steel Question dreamer Sailboats 10 12-07-2009 02:40 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 06:40 PM
Bending Stainless Steel mojounwin Metal Boat Building 4 10-25-2005 09:25 PM
Stainless Steel Question dreamer Materials 3 05-04-2005 02:25 AM
Stainless Steel hull? trouty Boat Design 3 11-18-2002 02:57 AM
