  #121
Old 02-09-2012, 04:09 PM
Rep: 670 Posts: 2,457
Climb back into you hole Paul and get back on your medication.....................
  #122
Old 02-09-2012, 04:10 PM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
Originally Posted by michael pierzga View Post
Have a good look at Volvo race boat mainsail ..."Lazy Jack "....leech control systems. If I see a good photo I will post
Here are photos of the V70s. No "Lazy Jack" leech control systems, whatever they are. I've sailed on quite a few boats with big head mains. None had any strange leech control systems.
Square top mains?-m4298_crop20_932x700_proportional_1320805316b30d.jpg  Square top mains?-m4305_crop20_932x700_proportional_132080532062da.jpg
  #123
Old 02-09-2012, 04:25 PM
Originally Posted by CatBuilder View Post
I've never had a square top, so I do not understand this.
Isn't there a car for the top batten?
Why do you need to take the top batten out? Can't it just drop down into a stack pack or something?
So... why would the stowing of the sail be any more difficult? I'm not following that.
The reason it is a problem is the angle of the upper battens on some sails. They are not parallel to the other battens, not perpendicular to the luff. Sometimes they are at very different angles, even 45 degrees.
So when you drop the sail and the batten is still attached to the mast track it can't lay flat on top of the stack. The solution is to have quick pins for the upper battens on this type of set up. After detaching the quick pins you can wrap the head of the sail around the stack with the battens lining up. Sometimes this requires 4 or more quick pins.
Of course you could simply opt for a big head with less drastic top, and have all the battens somewhat parallel. Then you could forgo the need for the quick pins.
Be aware that on some thin like a 50 footer you'll have the boom height above deck, plus the height of the stack. That can be difficult to negotiate when needing to pull pins or remove the halyard shackle.
  #124
Old 02-09-2012, 04:46 PM
Bruce Woods Bruce Woods is offline
Rep: 90 Posts: 94
Yes, or one could spend more money and get one of these auto stow thingys.
Here,,,,,,http://www.doylesails.com/anomaly/
And add more weight and complication right where you don't want it.
Regards
  #125
Old 02-09-2012, 05:43 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Ah now I see. Angled battens would be a big problem.
Michael: an example of what i was talking about with apparent wind would be a vespa. If you are doing 30 kph on a vespa, what direction does the wind come from 90% of the time?
Or... If one boat is doing 7 knots on a beam reach and the one next to it on a parallel course is doing 14 knots, which will have the sails more tightly sheeted at proper trim?
I suppose it's sort of like the theory of special relativity...
Kurt Hughes was right about this place.
  #126
Old 02-10-2012, 12:02 AM
CT 249 CT 249 is offline
Rep: 322 Posts: 1,173
CatBuilder, the issue is the one that Paul and Bruce described. As they said, there are ways around the issue, but those ways involve cost, weight and complication - as do heavily loaded full battens on most offshore-size boats in my experience, even when they aren't used for squaretops.
The figures that Mikko introduces may indicate that just sticking on a taller mast with a narrower head (which is more efficient according to aerodynamic theory) is less trendy but perhaps more effective, cheaper and simpler - depending of course on the boat.
Of course, it doesn't take a huge amount of time to pull the battens out, or unclip the cars, but then again the squaretop may also not save a huge amount of time on the racecourse or day or overnight cruise. YMMV.
I'm not trying to attack squaretops, which can be great for the right people and boat, just musing on the fact that while they may be trendy, they also may not suit most craft.
  #127
Old 02-10-2012, 01:47 AM
Mikko Brummer Mikko Brummer is offline
Rep: 124 Posts: 110
I was looking at doing a square top on my boat to add a little extra sail area and just for fashion (charter boat). So... why would the stowing of the sail be any more difficult? I'm not following that.
The sail won't go into the stack pack because of the diagonal top batten preventing the sail from being lowered all the way... the top of the sail will stop about the square top's width above the boom, unless you take the diagonal batten (which is needed to support the top) out or release the headboard from the mast.
Mikko Brummer
WB-Sails www.wb-sails.fi
  #128
Old 02-11-2012, 03:21 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 277
This is an interesting topic.
My micro-cruiser sports a Hobie 16 mainsail with full-length battens. The top batten is definitely diagonal. I'm considering a new mast: the existing is bent and I'd like to try a different section shape.
So before I invest in the new mast, I'm considering getting my sailmaker to cut the top of the Hobie sail to make it a flat-top. Trendy, yes.
I'd be giving up about 1% of the boat's sailplan but reducing the mast height by 8%. Reducing the mast weight by 2 lbs would be the same as increasing the keel weight by 10 lbs.
As argued on this thread, the boat may sail better with the square-top, but it may not all be for aerodynamic reasons.
  #129
Old 02-11-2012, 02:00 PM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
Originally Posted by Mikko Brummer View Post
Like in the case of the JPK the mast maker Eric Duchemin had to add 11 kg to the square top mast, to make it stand up for the extra loads. Even if the mast was 30 cm shorter. Not all of it was carbon fibre, though, there was double backstays and and the upper shrouds were re-dimensioned.
"Il y a 11 kilos de moins dans le gréement de la deuxième version, non seulement parce que le profil est moins dimensionné en unidirectionnel de carbone – puisqu’il n’y a plus de corne, donc moins de compression des lattes et surtout un pataras unique –, mais aussi parce que nous avons pu diminuer la section du haubanage. Dans la version à corne, il faut que le profil tienne lorsqu’il n’y a plus de bastaques. La section du profil est la même, avec 30 cm de plus et une potence renforcée en carbone de 35 cm en tête de mât pour permettre de passer un peu de rond de chute sur la grand-voile."
Would you point to some method on how to calculate the loads from square top main on the mast?
My search in Classification Societies Rules was not successful so far.
All the stresses in my designs are 95% of permissible.
  #130
Old 02-11-2012, 09:33 PM
sean9c sean9c is online now
Rep: 35 Posts: 85
Surprised at all the interested in big topped mains when it means the loss of a standing backstay and having to resort in either no backstay or having to tack twin backstays. No backstay seems a compromise in rig adjustability and having to tack backstays seems like a lot of work.
  #131
Old 02-12-2012, 01:29 AM
Rep: 323 Posts: 523
Well, some fractional rigs with swept spreaders and large mainsail do NOT need a backstay so dearly.
For pure racers, tacking a backstay is not that different from tacking the runners...
  #132
Old 02-12-2012, 05:01 AM
Rep: 58 Posts: 277
If I do cut the Hobie sail, are there any special considerations for the headboard? Is the halyard cringle in the same location relative to the mast groove? Or does the halyard cringle need to be moved more outboard?
I imagine that the stresses are still radiating down and and aft from the halyard and that the square-top is supported only by the battern. I'm expecting that there is no need for layers upon layers of sail material across the entire flat-top.
Any advice on this cut? Does anyone have experience with the details for this modification?
  #133
Old 02-13-2012, 12:01 AM
Rep: 323 Posts: 523
Well, the headboard will have to take a fair amount of horizontal pull away from the mast...
Tooling for a 37' top needed, CNC perfered? Jeff Thurb Boat Molds 0 11-07-2005 02:44 PM
12 1/2 Square Metres Alixander Beck Wooden Boat Building and Restoration 2 10-25-2005 04:49 PM
Top Hat with Carbon or E-Glass UD's Boa Boat Design 2 06-09-2004 06:49 AM
boats.com top 20 list Scott Sailboats 0 10-30-2001 04:47 PM
boats.com top 20 list Scott Powerboats 0 10-30-2001 04:44 PM
