I have often wondered about the pointing ability of square rig vessels.
MIR, the russian sail-training fully-rigged ship can sail easily at 45 degrees to the wind, and can with a good helmsman work up to 37 degrees. See http://home.t-online.de/home/klaus.beuse/baerbel/homepage.htm?/home/klaus.beuse/baerbel/eng_story4.htm for references. MIR wins races under handicap often, and especially when windward work is included.
Pelican of London, being built in the UK, is shown at http://www.adventureundersail.com/
and the work to base it on is at http://www.weatherlysquareriggers.com/
All these are comparable with bermudan rigs at 45 degrees or better. Etchells are regularly sailed at about 30-35 degrees.
Belem (ex Fantome) a French sail training barque is said to not get much above 80 degrees, and the STA brigs eg Prince William is said not to either.
The major obstacle is that of the bracing angle that the yards can obtain to the centreline, and this can be improved in most designs.
Either some of the above is ficticious, or there are a lot of square rig vessels that are not being sailed well, or need attention.
Any comments?
percy westwood
Any comments?
percy westwood
