Old 03-07-2010, 05:37 PM
keith66 keith66 is offline
Rep: 117 Posts: 223
I built a whitehall with a spritsail rig, she went very well & the sail was cut pretty flat, it was loose footed without a boom so downwind tended to generate rolling if you were not careful.
The ultimate spritsail rig was that of the Thames barge & they were handled by very small crews reputedly a man & boy. Probably the most efficient cargo carrying hull & rig ever evolved for the job they were intended for.
Old 03-07-2010, 10:33 PM
souljour2000's Avatar
souljour2000 souljour2000 is offline
Rep: 156 Posts: 417
Messabout... My belated thanks as well for the good points you made about loose-footed mains and their pros and cons...The bimini will probably get in the way alot...it's huge and since I got it for free and it's all stainless frame so I was really hoping to work it into the boat's overall rig somehow...just not likely to happen and like I mentioned...a small boat like my 20-footer is hard to rig a bimini efficiently... even when unfurled.... it will make for messy cockpit rails...Maybe I should have kept that big sombrero hat I used to have...think I got it a garage sale...Ranger if your still around..crab claws are cool...especially on a cat...
Old 03-08-2010, 09:51 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
I would suggest caution when using non-working area. I did some experimenting with sails on a kayak some years back, and it worked well on all points except upwind. I believe this was due to the paddler's frontal area creating drag.
Dances with Turkeys
Bow sprit in high seas. Shack Sailboats 35 11-09-2009 02:33 PM
sprit rig cutter & weather helm Oldlugger Boat Design 14 02-02-2009 09:40 AM
Extending bow sprit? Pylasteki Sailboats 11 04-25-2008 04:43 PM
Relationship between keel shape and rig balance question. quilbilly Sailboats 4 09-25-2007 03:16 PM
olson 30 sprit antoine1 Boat Design 1 10-04-2004 07:42 PM
