Old 06-19-2007, 05:20 PM
noledoc noledoc is offline
Rep: 10 Posts: 2
Sonar modification
Hello all,
I am considering converting a Sonar 23 to an "elegant daysailer" in the fashion of an Alerion 28 or Schock Harbor 25. The Sonar was chosen fo the following reasons,
Old 06-19-2007, 05:50 PM
Rep: 10 Posts: 2
Continued,
The Sonar was chosen for the following reasons, draft less than 4 ft(required), trailerable(required), low cost due to age, small jib for ease of single handing, large cockpit, no lifelines or hiking, relatively fast(PHRF 171), large enough lead keel for stability.
The modifications I am considering are as follows, any input that you have regarding desirability, applicability, cost or difficulty would be appreciated.
Hoyt Jib Boom to make single handing easier
Full Battened mainsail with lazyjacks and integrated sail cover such as Dyle stack pack
Add a 100-200 lb bulb to the keel since the boat will be sailed most often with one or two and increased rightting moment would be desirable.
Move the traveler aft of the cockpit and install a barney post for mainsheet
Install a retractable sprit for short handed assymetric sail off the wind. Below deck installation like J-80 desirable
Lastly, an electric auxilliary like the Harbor 20
Thanks in advance
D. Saint
Transom modification jimhales Fiberglass and Composite Boat Building 11 03-09-2006 07:41 PM
Catamaran Modification Howaya Boat Design 1 09-14-2003 12:04 AM
coefficient modification fradrigo Sailboats 0 12-02-2002 02:41 AM
Whaler Modification Archive Powerboats 1 06-12-2001 03:37 AM
Modification of transom Archive Powerboats 2 06-12-2001 03:37 AM
