Old 02-03-2011, 09:32 PM
Bruce46 Bruce46 is offline
Rep: 49 Posts: 81
Solid wood mast vs hollow wood mast
Perhaps I'm having a senior moment, however, I can't seem to find a reference on how to convert a solid mast to a hollow mast. The masts in question are to be free standing on a 23' cat ketch. According to Skene's, my main mast is 4.58" dia. x 24' and my mizzen is 3.85" dia x 22'
Main SA =135, Mizz SA = 88 sq. ft. I'm probally wasting time, however, I wanted to see how much weight I could save by making birdsmouth masts, and comparing them to masts of almuinum.
Old 02-04-2011, 08:46 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
You have two options:
First, in Hasler and MacLeod's book "Practical Junk Rig," there is a procedure for determining the section size and wall thickness for hollow wood free-standing masts.
Second, once you know the diameter of the solid wood mast, you can calculate the equivalent moment of inertia, I, and section modulus, SM, of a hollow mast.
For the solid mast, I = PI(OD^4)/64, and SM = 2I/OD
For a hollow mast, I = PI(OD^4 - ID^4)/64, and SM = 2I/OD
For equal strength, SM for each mast should be the same. For equal stiffness, I for each mast should be the same. Vary OD and ID until you get equivalency. For a wood mast, the wall thickness should be no less than 20% of the outside diameter.
I hope that helps.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 02-04-2011, 09:01 AM
Rep: 49 Posts: 81
Eric
Thanks very much, I should know that but the gray hair got in the way.
Old 02-08-2011, 09:40 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Originally Posted by Eric Sponberg View Post
... For a wood mast, the wall thickness should be no less than 20% of the outside diameter ...
Eric, what is the underlying consideration for that rule? I ask because I built a couple of masts with thinner walls - down to 12.5%. Based on my long-ago experience with thin-wall tubular structures subject to Euler buckling I concluded that the ultimate limitation was the maximum number of staves one was prepared to use. With walls at 20% of OD there is a max weight saving of only 36% compared with a solid mast of the same OD.
I am assuming that OD of the hollow mast is increased compared to the solid mast it is replacing. Does the rule apply for the same OD - cantilever strength and stiffness would hardly be effected - or perhaps the thick walls are to retain fasteners ...
Dances with Turkeys
Old 02-09-2011, 10:14 AM
Hi Terry,
I quote that 20% guideline only from what "Practical Junk Rig" stipulates (and the authors admit to not being engineers), and it is also used in "Skene's Elements of Yacht Design" by Francis Kinney for hollow wood stayed rigs. I dare say that with proper engineering and testing, you could reduce that guideline considerably for free-standing masts, as you apparently have done with your experience.
If I were to do such a study for free-standing masts, my consideration would be to determine the required thickness to prevent buckling during bending, which is not an Euler phenomenon since the mast is not under pure compression. Nevertheless, if the wall thickness is too thin, the section will collapse by buckling before the full strength of the wood is reached. For composite masts and tubes made of primarily unidirectional fiber with some off-axis fiber, for both fiberglass and carbon fiber, I have found that the minimum thickness-to-diameter ratio (using inside diameter) is 3%. If the t/ID ratio is less than that, premature buckling will occur. If it is more than that, usually the material will fail in compression before buckling collapse. Wood, therefore, having less modulus than carbon fiber certainly, would require a bigger t/ID ratio.
Eric
Eric W. Sponberg
Naval Architect
Old 02-09-2011, 04:19 PM
aka Terry Haines
Thanks Eric. They seem to stand up OK but I wondered if there was a specific theory behind the rule. I suspect there is a max weight-saving of around 50% when designing a hollow mast to match the strength of a solid one (using the same material) but I haven't done the math.
Dances with Turkeys
Should I repair my wood mast or use aluminum one? filiperosa Wooden Boat Building and Restoration 9 06-26-2008 07:36 PM
Wood Mast for 12m Classic Day Sailor ivansalasj Sailboats 1 03-27-2007 09:52 AM
Wood for a new mast SV Papillon Boat Design 3 12-25-2006 06:49 PM
Wood Mast and Boom kapdan Marketplace 3 03-06-2006 04:40 PM
Questions about wood mast design for 24' catboat Yoth Sailboats 2 04-09-2005 01:57 AM
