| Solid Glass Repair? I am looking at a boat that has been grounded. The hull is solid glass and ther are some crack's in the gelcoat aft of the keel. Surveyor said it is blistering but that it was not structer issure. Can these cracks be drummled out and then use some West System to repair them? Cliff |
| Surveyor says blistering but no structural damage? Good, good. Blistering can be fixed. I think Interlux makes some treatments for that. Solid glass is much easier to fix than cored as you don't have nearly as many things that could go wrong when it gets hit.
| Matt, Thanks for the reply this is what I was thinking. I am going to get hold of the guy who had it surveyed and get a little more info. Cliff |
| Stringer repair ?'s | scarabfreak | Fiberglass and Composite Boat Building | 16 | 02-22-2007 12:00 AM |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 09:26 PM |
| Glass Selection for Repair | Jim Herbert | Fiberglass and Composite Boat Building | 9 | 03-22-2005 12:04 AM |
| Glass over good plywood hull? | Ed Hoban | Wooden Boat Building and Restoration | 10 | 02-11-2005 01:26 AM |
| UK - Fibre Glass Workers Required | MnM Int. | Services & Employment | 1 | 07-07-2004 10:42 AM |
