Old 07-21-2007, 12:57 PM
tspeer tspeer is offline
Rep: 1313 Posts: 1,523
Do you find it difficult to get enough luff tension to maintain the leading edge shape?
Tom Speer
Old 07-21-2007, 03:05 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,267
thanks for the answers. i was thinking why you mentioned less heel
for a straight up wing, and figger the answer is the lack of twist
that again made me think twice on sketch (attached) i'm playing with,
as a bipod counters heel but adds drag to lift to some amount
Old 07-21-2007, 03:06 PM
Ilan Gonen's Avatar
Ilan Gonen Ilan Gonen is offline
Rep: 40 Posts: 23
It took some time and some more battens to have a nice tensioned leading edge. It is now much nicer than what you see in the web site (don't have new photos yet). It is not a problem any more.
Ilan
Omer wing sail
Old 07-21-2007, 04:19 PM
Ilan Gonen's Avatar
Rep: 40 Posts: 23
Yipster:
Mentioning less heeling for cruisers was for two reasons.
1. It shows less waisted wind forces and better water line,
2. most cruisers are sailing with their wifes. Ask my wife how important it is.
There is a leech twist in Omer wing sail. Please have a look in the gallery. It is clearly shown at the first three pictures.
Omer wing sail
Old 07-21-2007, 09:36 PM
Originally Posted by yipster View Post
...sketch (attached) i'm playing with,
If you want to discuss twin rigs like this, it's probably best to start a new thread . But when you do, this might be a place to start.
It really takes a multihull to make use of the concept because you need lateral separation between an inclined sail and the center of buoyancy to make the inclination worthwhile. As long as you trim the two sails the same, there's not a big difference compared to a single sail. The real gain is when you sheet them differentially. Easing the windward sail and driving with the leeward one does not reduce heeling moment about the lee hull, but it does produce an upward force. Easing the leeward sail and driving with the windward one substantially reduces the heeling moment about the leeward hull, but at the expense of a downward load. So I believe the rig is really best suited for landyachts and iceboats that can benefit from the reduction in heeling moments, but don't pick up a lot of drag with an increase in down force. And it's best suited for rigid wings because of the need to feather one sail or the other.
Tom Speer
Old 07-22-2007, 08:17 PM
CT 249 CT 249 is offline
Rep: 286 Posts: 1,140
Ilan;
Have you raced the wingsail yet? How did it perform? Can you please provide us with a link to results?
Thanks
Old 07-23-2007, 01:33 AM
Ilan Gonen's Avatar
Rep: 40 Posts: 23
No. Not yet. Just finished all phases of development. The polar diagram shows the official standard Elan 37 performance in blue and the performance of the same boat with wing sail in red. Sorry, it is not completed yet. Will be done in the near futur.
Omer wing sail
Old 07-25-2007, 04:49 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,647
Originally Posted by Ilan Gonen View Post
...The solution for better lift and less drag was a wing and, for different wind directions was a rotating wing.
I also wanted the wing sail to be simple and to be the right solution for every sailor. This goal led to a soft wing sail that can be hoisted and reefed, rather than rigid wings that are much more aerodynamically efficient but are not good enough for any other purpose but racing.
Of course, the problems were how to do it. The way I found the most effective was to use battens to hold the aerofoil shape. These battens are attached to what I call "sliding spreaders" (please have a look at the web site in order to better understand it) that go up and down the mast while hoisting and reefing...
Can only ask a quick question at this time as I'm on a trip to Seattle.
How do your 'sliding spreaders' rotate with the rotating mast??
Old 07-25-2007, 05:27 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Ilan,
I am curious as to how this sail differs from previous versions like the Flip-Flop rig (now the SwingWing) by Sunbird Yachts in the late 70's (UK) and the soft wing on Yves-Marie Tanton's "Magie Noire" (http://www.tantonyachts.com/834picsthumbnail.htm)
Can you explain? I am not trying to be negative (although I usualy succeed in the end ) but to understand the differences and how yours is better.
Steve
  #25
Old 07-26-2007, 04:41 AM
Ilan Gonen's Avatar
Rep: 40 Posts: 23
Omer wing sail
How do your 'sliding spreaders' rotate with the rotating mast??[/quote]
Brian,
The sliding spreaders slide up and down along tracks attached to the mast. They can not rotate relative to the mast. They rotate together with the mast.
Omer wing sail
  #26
Old 07-26-2007, 05:13 AM
Ilan Gonen's Avatar
Rep: 40 Posts: 23
Originally Posted by SailDesign View Post
Ilan,
Steve
Steve
I don't know were to start answering your question, however:
The #834 66' Frp. "Magie-Noire", is a free standing wing mast. It is not a wing sail.
There are also some Old Chinese junk / wingsails, some of them are very good.
Talking about wing sails only, I can say that Omer wing sail is the only one I know, that has relatively very good aerodynamic performnce, up wind as well as boat speed in all wind directions (see performance/polar diagram), it can be hoisted and reefed, has variable geometry and the camber is easily changed and trimmed, very easy to handle, good for short hand etc.
I think it would be better if you looked at www.omerwingsail.com to see all of these differences.
Hope you keep on being positive after visiting the web site
Ilan
Omer wing sail
  #27
Old 07-28-2007, 08:28 PM
Brian,
Sorry, I did not notice the tracks at first glance. I was in a hurry out the door for a trip at the time I first looked.
  #28
Old 07-29-2007, 02:35 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
Originally Posted by mydauphin View Post
Question to all... How do you calculate the power of a sail compared to horsepower? I know how much hp I need to drive my boat a certain speed. How do I know how much sail I need to do same?
Not wanting to disrupt this thread, but to get this question out of the way, you need to compare sail to weight ratios of other designs similar to yours. Use the Bruce Number which is formulated thus:
Bruce number = square root of working sail area in square feet divided by the cube root of the displacement in pounds. Racing designs will yield 2 or more. Less than 1 will be quite sluggish.
Now, back to the wingsail action!
Trev F – Amateur designer and part-time layabout.
  #29
Old 07-30-2007, 09:43 PM
Rep: 472 Posts: 1,391
So how can you tell if one type of sail is more efficient than other.?
So how can you tell if one type of sail is more efficient than other?
For a given square foot, how would sail wing compare to regular sail? How would you do numbers?
  #30
Old 07-31-2007, 06:30 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
The scientific method is the double blind test. However, one boat, using the two rigs in turn and sailed by the same crew, should come up with some good numbers. The nominal square footage of both rigs should be the same.
That is how to compare the efficiencies. It was by testing various rigs, Gaff, Marconi, Sloop, Cutter, Schooner, Ketch, Yawl etc., that conclusions were drawn and sailplans evolved. Ilan has taken his fighter pilot knowledge and created his Soft Wing sail. It works! His boat originally had some kind of rig, which he replaced with his Soft Wing. Let's wait until he confirms whether he kept the same area of sail, or whether he downsized, but kept the same speeds.
That should help.
Pericles
Boomless Gaff "Wharram type soft wing" mark in nj Sailboats 5 11-20-2009 07:11 AM
Wing Sail design AleX`G Boat Design 23 10-20-2009 08:12 PM
Soft Wing Sail rhiemstra Boat Design 9 08-28-2008 05:21 PM
Sail wing tips? AleX`G Sailboats 7 04-09-2007 06:17 AM
C of E for small landsailor soft sail Guest Boat Design 2 02-17-2004 04:29 PM
