| What size boat are these lines going on? |
| 1/4" is pretty small for a 16 ft boat. You might want to upgrade the blocks one day soon. |
| just fer the record, (twisted) the right term is laid rope, and nylon is fine, , manila feels nice, but where can you get it, ) Spectra is wonderful and expensive BUT in 7 years of exposure the sheets on the boat I skippered(the owners left the headsails up 7 years ) in the ultra violet rays of this forlorn place, have stood up to the sun, as has the braidI cant splice braid, so I use laid for tieing up, and also for ground tackle use laid nylon as backup for the chain rode unless you have togh hands as soemone said, laid is not good for dinghy sheets where you have the main in hand, does;nt lay nicely on winch drums either I have stopped splicng the mainbrace |
Roy, the trouble is thse days, hardly any shop assistant will know terylene from nylon, |
| The Boat is a 16 ft. day sailor....22ft mast 9 ft boom about 6 feet or so on the beam. I already have to replace the cleats since most are just broke from being outside and not used for 7 years, and I am missing one block and another one is worn pretty bad so I could see updating all of the blocks and making sure they can hold heavier line... |
If west Marine's "advisor" were here, the most practical, least expensive, and easiest to work rope would probably not get much attention (but then, West's advisor owns stock in West). I think its underrated, considered inferior to braided in every way (due in part to salesmanship, and in part to the way people want what the big boys use). In fact, idacron laid rope is twice the strength of manila and doesn't rot either. Alan |
#25
| Wood Choices for Cold Molding | FastLearner? | Boat Design | 37 | 03-29-2010 09:30 AM |
| rope rub rails | tugman | Materials | 4 | 03-17-2007 08:45 AM |
| Rope cutters / bearing protectors | h4marine | Press Releases | 0 | 03-24-2004 05:51 PM |
| Outboard engine choices | ark | Sailboats | 5 | 11-30-2003 01:43 PM |
| Boat choices... not specifically design related | curtis73 | Powerboats | 1 | 03-26-2003 12:33 AM |
