Old 09-20-2010, 01:02 PM
jgrant86 jgrant86 is offline
Rep: 10 Posts: 3
Snipe Help
I recently purchased a used snipe that seems to be in pretty good shape for the most part. Up near the bow the deck is not reinforced and will flex easily. Most snipes I have seen use some sort of reinforcement up there and I didn't know if anyone had recommendations on how to do so.
Old 09-20-2010, 01:17 PM
mark775
That spray dodger and its backing where intended to stiffen and apparently didn't do the job? Where is the thing flexing? My first instinct is that it is non-oriented chopped strand construction (chopper gun), which is fairly stiff for its strength - so if it is flexing, it is also near catastropic failure. You are right in fixing before the problem arises.
I looked again and it said "near the bow" - Sorry. Well, that's easy. You are just concerned about when you walk on it? Just glass almost any shape into it. Cut a paper towel cardboad (the roll) in half lengthwise and glass it athwarts with whatever glass and epoxy resin you can find. You're not building a piano here - if you want advice on making a finer craft of it, write back and expound upon your expectations.
Old 09-20-2010, 02:21 PM
Rep: 10 Posts: 3
You are right about it being close to catastrophic, walking on it would probably break it. The entire deck area from the mast to the bow is flimsy, especially about mid span. Many photos I have seen of similar boats seem to have supports in that area. I am familiar with fiberglass work but just wasn't sure if there was any particular method commonly used in other snipes before I go crazy with the resin.
Old 09-20-2010, 02:47 PM
Rep: 1493 Posts: 7,447
Snipes are built to be raced. The foredeck is not to be walked on really. You may sit on it gently to reach a dock or something. By class rules there is a foam core, that is adequate.
Old 09-20-2010, 04:18 PM
Rep: 3125 Posts: 9,403
Yep, they are on the delicate side, but not so bad really. A common method is to use foam or cardboard tube (halves), of course covered in polyester or epoxy and fabric, to act as deck beams. This is light, strong and eliminates the flexing. It also handles the pucker that is usually seen at the jib tack fitting.
Old 09-20-2010, 06:41 PM
Rep: 10 Posts: 3
Thanks for the help guys.
how do i make a kick-up rudder for my snipe fercammo Sailboats 13 10-28-2011 06:51 AM
1947 Snipe Woody Restoration mrector Wooden Boat Building and Restoration 11 05-09-2011 07:00 PM
Can a 40 year old wooden Snipe be competitive? smtoole Sailboats 8 07-17-2010 10:14 AM
snipe rpairing centerboard case pepin Boatbuilding 6 05-30-2008 06:44 AM
Snipe plans Ivandro Sailboats 1 07-05-2004 09:03 PM
