| snipe centerboard weight is the weight of the centerboard important on a snipe? i built a very light one from polycarbonate dont know if its going to work correctly. does any body know about this topic? fernando |
The class website has very specific rules regarding shape, weight, materials and allowed edge fairing of the plate metal used. If you aren't racing your boat, your board may work fine. The daggerboard trunk is designed for 1/4 inch plate, therefore unless you have changed the trunk, a polycarbonate blade will not be strong enough in sheer strength at the same dimension. It will also be much easier to fracture and shatter on impact. I think my steel plate weighs between 75 to 85 pounds (around 35 kilos). -- CutOnce |
| A Snipe is not a Snipe unless it follows class rules. They are very strict and say that anything not expressly permited by the rules is not allowed. Polycarbonate is very flexible and will make a terrible centerboard.
__________________ Gonzo |
| snipe center boar Quote:
| I crewed on a snipe for a few years as a kid, from about 10-14 year old. That blade was a real bummer to pull up, especially in a breeze. I can understand the motivation to make a lighter one. But as others have said, it won't be one-design. A light blade should help performance as long as it is strong enough. I think the tough part would be making a blade that won't break that is not metal. If I remember right, the slot in the hull is really thin, so getting enough bending strength in a non metal blade could be a challenge. |
| The slot in a Snipe is 3/8"
| You can use a 3/8 aluminum plate which will be about 35% of the weight of the steel plate. The boat will sail just as well if you can hold it flat. The steel plate does add a little to the stability of the boat but not so much as to be a deal breaker. The aluminum plate will cost 3 times that of a steel plate and maybe more. Fortuneately it can be cut to shape with an ordinary band saw. |
| How do I calculate the weight needed to ballast a centerboard? | bntii | Boat Design | 2 | 08-25-2011 05:42 PM |
| Snipe Help | jgrant86 | Sailboats | 5 | 09-20-2010 06:41 PM |
| Intro & my project: adding more weight to foam core swing centerboard (hunter 22) | sprockett | Sailboats | 0 | 03-20-2010 04:32 PM |
| snipe rpairing centerboard case | pepin | Boatbuilding | 6 | 05-30-2008 06:44 AM |
| Adding weight to daysailer centerboard | techcontrol | Sailboats | 11 | 10-16-2006 07:23 AM |
