| smallest sailboat which has an inboard engine hello, what should be the smallest size of a sailboat but still she will have an inboard engine. cheers |
| I've seen a sailing kayak equipped with an electric trolling motor.
| I had a 20' motorsailer with a 15hp yanmar diesel....700 mile range under power. |
| I can remember 14 to 16 ft double ender? lap-strake planked heavy rowing boats fitted with a little petrol one cylinder salt water cooled inboard operating in the "sheltered waters of what is now the Gold Coast around the 50's to haul nets out from the beach and everyone strolling along would help to haul the net in and get a fish or two as thanks for their help, also some were later available as hire boats for fishing/crabbing in the rivers....
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
| In the '70s I had an 18' lateen rigged flat-bottomed, long keel, double ended, decked over weekender with a 5hp Kermath. It had a standing well aft, and I pitched a pup tent on deck. They loved it in Tarpon Springs! |
| Code: I had a 20' motorsailer with a 15hp yanmar diesel....700 mile range under power. but i am espacially interested in coastal cruisers. please send more examples. doug lord, that sounds nice. what was the model of your boat? cheers |
Hi urisvan-thanks. See this thread: 20' Motorsailer I designed the little motorsailer based on an 18' daysailer/weekender that I had designed for T Craft boat company. |
| thanks, what i had in my mind is a sailboat, capable of going in heavy seas, maybe not in the ocean, but in agean sea, where there are high winds sometimes(not very big waves). |
| look at something like the smaller Lombardini 2 cyl inboard marinised engines - fairly light and seem quite popular in Europe.... 500cc and 700cc diesels....
| I've read that a few Cape Dory Typhoons came with inboards, but I've never seen one. Can anyone confirm (or deny) this? |
| A Flica, would fit your request nicely. ![]() ![]() ![]() ![]() 20' on deck, standing headroom (5' 11"), 8' beam, 3' 3" draft and displaces about 3 tons. A good little sea boat by Pacific Seacraft She's rough water capable and would be fairly comfortable, considering how short she is. |
| Hey, that is quite cute....
| Look at: International Folk Boat, or Cheoy Lee Frisco flyier. |
| Or there is the Anderson 22, Oliver Lee design, fast & seaworthy with lifting keel, mine has an RCA Dolphin 12 HP petrol inboard thats like having a smooth turbine under the deck. http://anderson22class.co.uk/ |
| In order to round up some more ideas to chew on:
If I turn back to the original question, which I interpreted like "is there a minimum size for a boat to carry an inboard engine?", as a mechanical engineer I would say "No". One could probably use the smallest air cooled single cylinder diesel engines (like e.g. the Lombardini 15LD225, the Mitsubishi L2E or the Yanmar L48V) fitted out for a marine environment. At a weight of 25-35 kg you should even be able to mount that in a small beachboat. (with a max. power < 5 HP your boat shouldn't be a whole lot bigger )Cheers. |
| Inboard Engine to Automobile Engine Conversion ?'s | Stingray230 | Gas Engines | 2 | 09-26-2007 07:04 PM |
| inboard well for outboard motor in a sailboat | dblount | Boat Design | 4 | 06-07-2007 07:04 PM |
| mercruiser inboard engine | mikebhunt | Inboards | 4 | 08-09-2006 12:57 AM |
| Replacing an outboard engine with an inboard engine | boere | Sailboats | 1 | 09-16-2005 08:49 AM |
| Replacing an outboard engine with an inboard engine | boere | Boatbuilding | 0 | 06-23-2003 05:21 AM |
