Old 04-20-2011, 10:15 AM
BobBill's Avatar
BobBill BobBill is offline
Rep: 104 Posts: 379
Location: Minnesotan wakes up daily, a good start, snow or not, in Gingerville.
Small Dinghy Rudder Material
Can I use one piece of yellow (Alaska) cedar or mahogany for rudder blade?
Leave a place better. Congress is the enemy!
"All ya gotta know!" Dog. Winona.
Old 04-20-2011, 02:49 PM
Rep: 3125 Posts: 9,403
A single piece of solid wood will likely warp, cup, check or other wise cause trouble. A strip planked blade is a better choice as it doesn't have the issues associate with solid stock. Though I don't recommend it on larger craft a small dinghy (assuming a Nut Shell or similar) will have a lightly loaded rudder blade, so plywood can be used. If you do use plywood, again, not just one piece. Glue two or three pieces together, on top of each other then cut to shape. For example, use 3 layers of 1/4" plywood to make a 3/4" thick blade. For extra strength, cant each plywood layer 12 degrees to the previous layer (cant the port side forward 12, the starboard aft 12 and leave the center layer straight up and down).
Old 04-20-2011, 02:55 PM
BobBill's Avatar
Rep: 104 Posts: 379
Thanks Par. I am off looking for some strips to epoxy up somewhat as you noted. I think the mahogany might be available. Will post some pics.
Old 04-20-2011, 10:42 PM
Mahogany is nice, but not necessary. I prefer softwood for small boat rudders anyway. They experience less moisture gain then hardwoods, they're lighter and are easier to work. If you do strip plank a blade, make sure you use quarter sawn stock and alternate the grain orientation with every other strip. This eliminates warping and internal stress issues that can arise if most of the grain is facing the same way. Again, if it's a Nut Shell or similar type of dinghy, just glue two pieces of 1/2" plywood together and call it a day.
Old 04-21-2011, 06:43 AM
BobBill's Avatar
Rep: 104 Posts: 379
Par, I believe the ply is best here too. The original rudder is ply mahogany and lasted, so, if I can find the right stuff. will do as ply core. Appreciate your knowledgeable help.
Dinghy Rudder Change on Kite Dinghy BobBill Sailboats 1 09-02-2010 04:03 PM
Dinghy Rudder Design BobBill Sailboats 10 12-07-2009 02:20 PM
Small Dinghy Trav/Rudder Assy, Needed BobBill Marketplace 0 11-14-2009 06:53 AM
Hobbie Cat Rudder Core Material ? Flumixt Fiberglass and Composite Boat Building 2 10-17-2007 05:35 PM
Small dinghy joebobb Boat Design 4 02-26-2005 02:42 PM
