| Small aft sail? What is the proper name of the small aft sail set when hove to, in a storm? It may sound funny, but I want to rig one to keep my 42' motor boat pointed into the wind during high winds. I'd like some talk, advice & fesign poibters on this. Thanks
| The riding sail or steadying sail was often seen on passagemakers and larger power craft, but has falling victim to styling dictates of modern marketing. They can be used at anchor to keep your head up so the boat doesn't march around it's hook and while underway to ease rolling conditions, as well as during a hefty blow. |
Yeah, "steading sail, Thanks. That is what I want for my house boat, keeping it into the wind when moored. Is there a design feature to one? Do I just plant a short mast up against the rear cabin ,add a boom and make a right triangle tarp? Seems nothing is ever that easy. Put pad eyes on the outer corners of the rear deck to hold the boom and I'm done? Thanks.
| The "stern" sail can be smaller because it has more leverage? Is there a reason the sail is located on the cabin, other than style?
| Converting to a motorised sailer ? Be a bonus if the sail could have more uses... just a thought.
Not converting, just adding. I did notive the cabin version looked rigged to also sail the boat. My house boat has no keel to speak of. Is there a advantage for ME to go to rge effort of a cabin version?
| I didn't know you had a house built on it ![]() To be able to sail the house I mean boat my female instinct tells me the sailing area should be larger than the house's I mean boat's windy surface.Could be done if a mast can be placed where it would be carried by the structure. Running you could use a kite to tow you around. One of the threads have some stuff on it... Brian Eiland is it ? New Age Trawler/Motorsailer; Kite assisted PowerYacht
http://images.google.fi/imgres?imgur...%3Dfi%26sa%3DN Best Sjark aft sail I could find in 2 min.. |
| Well, if you'r going to put a small sail up I guess it can stand up anywhere. If you have something larger in mind they are heavy and large sails add a lot to pushing the mast down.
| Well, 30' sjark has aft sail about 6m2. Mast is free standing 3'' steel tube sometimes with a couple of 90deg curves (if bolted to other side) or with a wishbone from both of them. The overall loads aren't as heave as with traditional sails, bcs these don't do anything else except turn the stern down. Sail itself reaching out like Wind-vane, actually that's more precise to call it rudderles wind-vane |
| [quote=Fanie;183322]I didn't know you had a house built on it ![]() To be able to sail the house I mean boat my female instinct tells me the sailing area should be larger than the house's I mean boat's windy surface.Could be done if a mast can be placed where it would be carried by the structure. Running you could use a kite to tow you around. One of the threads have some stuff on it... Brian Eiland is it ? [url]http://www.boatdesign.net/forums/showthread.php?t=20319&highlight=brian+eilan . Why have a boat if you don't put a house on it The roof isn't designed for a big mast. I'm thinkimg Teddy is right, put it on the stern, keep the lounge chairs & drinks on top.
| Traditionally a small sail set aft of the wheel or tiller on a sailing boat was called a SPANKER. K9 |
| mizzin? |
| Thats the mast its set on. The sail is a spanker. |
| Aft Mast Main Sail type | Fanie | Open Discussion: All Things Boats & Boating | 12 | 11-11-2007 09:49 AM |
| Wine glass stern and small aft-cabin sailboat | xarax | Boat Design | 2 | 07-12-2007 07:51 PM |
| Small Sail Designing Tips | Lakefield Dan | Wooden Boat Building and Restoration | 1 | 04-26-2005 07:39 PM |
| C of E for small landsailor soft sail | Guest | Boat Design | 2 | 02-17-2004 03:29 PM |
