Old 07-21-2006, 05:55 PM
globaldude globaldude is offline
court jester
Rep: 10 Posts: 110
Small 60 - 90 degree tunnel to get bigger prop viable ?
Hi guys, I did try to ask this question on an old thread,but apparently it was too old for me to reply to so I'll ask it here .
I have a shoal draft yacht [ in construction ] and am shortly to drop the keel to enable me to fit a larger prop - amongst other things - I was wondering about fiting a semi pipe / tunnel [ probably only 60 - 90 degrees ] to enable a larger prop / better, or more tip clearance .
I have a big old slow reving lister [ 1100 rpm max ] with lots of tourque so a large prop = better efficiency , right !?.
Pete.
Old 08-15-2006, 02:16 PM
Rep: 696 Posts: 1,232
Pete;
Try to find a copy of Dave Gerrs' ropeller Handbook. It contains a wealth of information about application and selection. There is also information about Kort nozzles and the like.
I believe that shrouded props work well for low speed applications but not well for high speeds. With the big Lister you are not likely to be a speed demon so perhaps your idea has some merit. If your Yacht is a sailboat then the big prop will make much drag while under sail. If it is a power boat intended for moderate speeds, then a large diameter prop is probably more efficient than a smaller one.
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
How can i put a bigger motor on a smaller boat? willfishforbeer Boat Design 10 06-15-2006 08:16 PM
My first effort - now for bigger ones Aberdeen Boatbuilding 8 01-20-2006 07:19 AM
Degree.... Dave_raul Education 1 02-24-2005 11:03 AM
small slow tunnel boat charlie Boat Design 12 11-17-2003 09:38 PM
