Old 09-09-2005, 04:24 PM
Andy P's Avatar
Andy P Andy P is offline
Rep: 10 Posts: 95
sloop or cat rig?
What is better in limited area development classes?
Would an A class cat or int Moth be faster with a jib?
or an int Canoe faster with mainsail only?
I remember the formula 40 multis used their storm jibs ( ie of minimum size because they had to have a jib )
Old 09-10-2005, 10:09 AM
Doug Lord
Main only
In discussing rigs for high speed sailing with Barry Spanier- Gaastra rig designer and designer for the rigs on Long Shot- he is convinced the fastest rig for high speed sailing is a main only camber induced square top rig, preferably unstayed.
Eric Sponberg and I are using such a rig on our 14.6' foiler.Our 130sq. ft. rig uses a variation of a wishbone boom that doesn't work like a "normal" wishbone. We use it specifically to allow the forward 30% or so of the sail to be brought right down to the deck-while allowing good clearance for the crew. It has an athwhartship structural member immediately aft of the forward part of the sail to which the mainsheet is attached. The midboom mainsheet operates on a very wide traveller so there is no need for a separate vang. I think a rig like this might be ideal on an IC..
Old 09-12-2005, 02:34 AM
Packeteer Packeteer is offline
Rep: 10 Posts: 64
don't suppose we could get a picture?
Old 09-12-2005, 09:31 AM
Doug Lord
No picture yet-we're still trying to raise the money to finish the design and manufacture it. However, I've built a model that illustrates the wishbone quite well- maybe a picture of that would work for now.I'll see what I can do..
UPDATE: I've got three pix I can e-mail anyone interested in seeing the rig etc on the aeroSKIFF foilier. The wishbone and reason for it can be seen fairly well. The pix are of a somewhat detailed model of the boat. Unfortunately, I can't post them here.
lorsail@webtv.net
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 08:19 PM
biplane rig on a C cat c_spray Multihulls 11 10-30-2005 12:00 AM
Big Cat, alt CB's & sail rigs brian eiland Boat Design 0 10-01-2003 11:41 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
