Old 09-26-2003, 12:46 PM
Zaynab Zaynab is offline
Rep: 10 Posts: 19
Sizing Ketch Standing Rigging
I am trying to figure out how to size a ketch rig (mast and standing rigging). Larsson explains how to size a single sticker's (sloop) rig, as does Dave Gerr in "The Nature of Boats" (easier to understand but less precise than Larsson). Neither book explains how to size the rig of a ketch.
Suggestions; links; book titles appreciated.
Zaynab
Old 09-26-2003, 01:29 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Suggestion 1 - Assume that the mizzen is used alone for really heavy weather. Size the rigging as you would for the mainmast, but allowing for 75% of max RM as the criterion. This "assumes" a headsail is using the other 25%.
Steve
Old 09-26-2003, 02:17 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Skene's Elements of Yacht Design addresses this issue.
Old 09-27-2003, 12:25 PM
Rep: 10 Posts: 19
Thanks Mmd and Steve for the quick replies. I'll have to order Skene's ... I had hoped to save a little and get more recent data by buying Larsson's book. But anyway, all those design books look really cool on my bookshelve.
Steve: I am interested in the following approximate sail areas: genoa 25%, main 40%, mizzen 35% (high roach main and mizzen; swept spreaders, no permanent backstay).
Zaynab
Old 09-27-2003, 01:34 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Zaynab, normally I would feel bad for a person who was forced to buy a moderately expensive book (aren't all books too expensive? ) to answer a single question or two, but I think that you will find so much useful information in Skene's that you will refer to it many, many times in the coming years.
Old 10-10-2003, 06:13 AM
Rep: 10 Posts: 19
Skene's Yacht Design
I just received Skene's 8th edition and you are absolutely right, although the author has some ideas that seem to be outdated. I do not want to start a lengthy discussion about long vs short keels, etc., but boatbuilding fashion clearly has changed, and Larsson's book is more modern in that respect.
Old 10-10-2003, 07:46 AM
SailDesign's Avatar
Zaynab, it's worth remembering that when it was written, Skene's was pretty dang up-to-date. The first edition is from 1927.
Old 09-07-2004, 12:06 AM
Rep: 1623 Posts: 2,343
The problem with the ketch mizzen is all that added drag from the second rig.
To compensate the mizzen should be around 20% of the total sail area (according to Pierre Gutelle it should never be less that 18%).
That way the drive to drag gain is acceptable. If the Mizzen starts getting too small you just slow your boat down.
Mizzen masts should be designed with the mizzen staysail in mind. This is the big winner on a ketch rig.
Mike Johns.
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
dyneema and kevlar standing rigging???? mistral Sailboats 3 10-01-2004 04:44 AM
Modifying sail plans and standing rigging tigreg Sailboats 2 09-21-2004 07:30 PM
Sail & Rigging plan for 44' ketch Willallison Sailboats 4 01-15-2003 03:00 PM
Rigging sizing spreadsheet? interlude Boat Design 0 12-21-2002 03:24 PM
