| shroud attachment...steel or aluminum boat is a 1972 Morgan 42 MkII. The shroud chainplates are attached to the hull via big stainless bolts into a three foot long section of steel u channel beam...four inches wide and maybe 1/4 thick. The u beam is very corroded and need to be replaced. I am thinking of replacing with aluminum to reduce the corrosion problem. Make sense? Issues to worry about? How do I size the aluminum beam to get the same strength as the original steel? |
| You need to find out what grade of steel the original chainplate is. You'd be safest replacing with a high grade stainless of similar/same size as the original. If the attachment from the turnbuckle is stainless, it's probably not a good idea to connect a steel pin to an Aluminum chain plate. Good marine stainless grade AL6XN. |
| Stainless steel / Aluminum | hendrikus | Boatbuilding | 5 | 06-30-2006 07:40 PM |
| Aluminum vs. Galvanized Steel | WAHiggins | Materials | 6 | 06-02-2005 01:32 AM |
| Steel and Aluminum Boatbuilder, Pac.N.W. | SolomonGrundy | Metal Boat Building | 1 | 03-21-2005 09:33 PM |
| Overuse of cathodic protection on aluminum or steel hulls | Thunderhead19 | Boat Design | 6 | 02-28-2005 07:20 AM |
| Looking for job with steel and aluminum Boat builder | Services & Employment | 0 | 03-26-2002 10:33 AM | |
