  #46
Old 05-18-2011, 12:37 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Originally Posted by sharpii2 View Post
As for your simplified formula, I can't say. I have to first figure out where you got the '29' from.
By re-arranging your formula and grouping numerical constants together, you arrive to:
0.03 / [5*sqrt(0.03)] = sqrt(0.03) / 5 = 1/28.9 = (approx.) 1/29
  #47
Old 05-18-2011, 01:02 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Originally Posted by viking north View Post
Sharpii2--Don't think it ever totally went out of favour especially amoung serious blue water sailers.(cruisers). Like many things in life it's all a trade off and as you state, with the price of fuel never again being within the average Joe's budget, motorsailers and long keels will become the vogue both with the older sailer and the power boaters. In my entire 40 odd years of sailing I've never owned a fin keeler simply because, when compared with a long keel they fail where it counts most to me.--
Hi, Viking.
What sort of boat do you own?
A sailboat? a motor sailor?
Does it have a full length keel?
How close to the wind can it point?
I would agree with you for the most part. But I think the short, deep fin keel is here to stay. Although they can get in trouble in heavy weather, they can get out of trouble quite easily. A bigger rudder and a commitment to always keep the boat moving seems to be the ticket. At least that's what I garnered from reading books about the 'Fastnet' and 'Sydney-Hobart' disasters.
Lets face it, ocean cruising is quite a specialty use of a sailboat. Many dream, few partake. So, the deep, short fin keel may dominate in even that for quite some time. It, with the right reenforcing and equipment add ons, can be more than enough to meet the challenge. It may actually be more sea worthy too. Not that the boat is more seaworthy, but that the crew is. They are used to this kind of boat and, over the years (hopefully), they have learned its little tricks and quirks. It's when the boat does something totally unexpected in a bad time that the real trouble begins.
I think a return, or partial return of working sail, or working sail assist, will bring the long keel back as a more or less standard norm. It is one thing to ride a boat that rolls and pitches sharply, from time to time, across an ocean. It is quite another to work on its decks the majority of ones working life.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
  #48
Old 05-18-2011, 01:23 PM
Rep: 471 Posts: 954
Thanks, Daiquiri.
I see now why you are the engineer and I'm the security guard.
The only problem I see with this is that the 0.03 number is intended to be a variable constant, meaning it can be replaced with 0.02, 0.025, and so on, depending on the S/D of the boat and its intended speed range. A higher S/D ratio can mean a lower constant, as, with the greater working sail area, the boat can be expected to be moving at a higher average speed.
I suppose you could put it ' /29 to 35', using your version.
  #49
Old 05-18-2011, 01:37 PM
daiquiri's Avatar
It's your formula, I've just re-written it in imho visually simpler terms (no big deal).
I don't have means to check if your formula is correct - perhaps Dskira, PAR, Tad Roberts or some other designer with more experience in designing classic boats with long keels could give it a try.
Cheers!
  #50
Old 05-18-2011, 04:51 PM
viking north viking north is offline
Rep: 727 Posts: 1,161
Motorsailer of course is there any other type . I can sail as close or closer to the wind over a longer distance than a fin keeler, simply fire up the engine and let it tick over and assist the sails. That way I don't need a generator to charge up my batteries in route or when i arrive in port. I can also enjoy all the comforths that electricity can provide while beating to windward in messy cold weather in a cosy heated wheelhouse. Gave up that 100% sailing hero mentality years ago--not that there's anything wrong with it , just not my cup of tea anymore. Don't sleep in a tent anymore either but I do hunt deer, moose and bear without bait, the old fashion way on foot tracking. Geo.
Fin keel mermont Boat Design 3 10-26-2010 01:12 PM
Cutting a Fin Keel alex folen Boat Design 15 03-05-2009 10:48 PM
Fin Keel Technology delmarrey Boat Design 8 07-14-2007 10:36 PM
Fin Keel to Lifting Keel on my Columbia 28 SteveWinNH Sailboats 5 04-05-2006 05:35 AM
Fin Keel CBrown Sailboats 7 08-10-2004 07:06 AM
