Old 09-15-2009, 09:41 AM
Fidippide Fidippide is offline
Rep: 10 Posts: 3
Separation bubble
How can I display separation bubble with XFOIL on the surface of a NACA simmetric 4 digit profile? Thanks.
Old 09-24-2009, 12:22 AM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
The boundary layer calculation in XFOIL is an integral method, so it doesn't actually calculate the details of the flow in a separation bubble the way, say, a Navier Stokes code would do. Instead, it calculates parameters that determine the overall characteristics of the boundary layer.
You can often spot the separation bubble in the pressure distribution. It will be characterized by a nearly flat spot that extends out from the inviscid distribution, then rapidly drops to the inviscid distribution after transition occurs within the bubble. Here's an example:
From the OPER menu, you can go to the VPLO menu and plot the skin friction. The skin friction will be negative or zero in the region of separated flow. The shape factor (H) plot can also be useful.
The BL command from the OPER menu will plot boundary layer velocity profiles. Or use the BLC to plot a specific velocity profile on the airfoil of the CPX plot. Look for profiles with inflection points.
Tom Speer
Old 09-24-2009, 02:01 AM
Petros Petros is offline
Rep: 717 Posts: 764
Many years ago when I worked in aerodynamics with the early 2-D and 3-D main frame programs, we would create a foil shape by combining the foil with the attached separation bubble, estimated from the stream line data and the method Tom outlined above. this gave strange, really thick sections, but it worked.
The program would build the boundary layer over the outside of the combined separation bubble and airfoil shape to approximate the actual airflow. It gave fairly good approximations of the lift and moment coefficients, the drag was never very accurate. If I recall, X-foil is a fairly simple program that might work the same way.
Old 09-24-2009, 05:21 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,476
Originally Posted by Petros View Post
...we would create a foil shape by combining the foil with the attached separation bubble, estimated from the stream line data and the method Tom outlined above. this gave strange, really thick sections, but it worked.
It sounds to me like you have created Stratford pressure distribution over the airfoil. If so, the final result you had obtained must have been something like Liebeck's airfoil shape?
Old 09-24-2009, 11:20 PM
Rep: 717 Posts: 764
That looks about right, but there was a think surface trailing way behind the TE from the separated flow causing a very thick boundary layer.
Old 10-03-2009, 12:36 PM
...If I recall, X-foil is a fairly simple program that might work the same way.
XFOIL has an inviscid panel code coupled with an inverse integral boundary layer method. The boundary layer method specifies the skin friction at the surface and calculates the resulting pressures. The boundary layer and the outer flow solution are iterated together to converge on the solution. The boundary layer method is basically the same as used in the ISES & MSES codes. It is capable of handling limited amounts of separation, where direct boundary layer methods (that calculate the skin friction given the pressures) cannot. This is a much more sophisticated capability than the earlier methods of loosely coupling the boundary layer and outer flow solutions.
ISES/MSES use an Euler method for the outer flowfield instead of potential flow, which gives them the ability to handle compressible flows better. But at low speeds, XFOIL is state of the art.
Tom Speer
Old 10-04-2009, 04:31 AM
daiquiri's Avatar
Can someone please tell me if there is a GUI version of XFOIL available?
Also, do you know if any research has been done in order to verify the degree of error given by XFOIL when treating flows separated at leading/trailing edge, and flows with separation bubbles?
Old 10-04-2009, 07:05 PM
Check out Profili.
There's been a lot of validation of XFOIL.
Here's a small sample:
http://www.ewec2009proceedings.info/...esentation.pdf
http://ftp.rta.nato.int/public/PubFu...AVT-168-32.doc
http://waste-environment.vin.bg.ac.y...zanovic%20.pdf
http://ftp.rta.nato.int/public/PubFu...AVT-168-32.pdf
http://www.mandhsoaring.com/Why%20Winglets/TS-03.pdf
Tom Speer
Optimum Cat Hull Separation? alidesigner Multihulls 7 05-24-2009 10:44 AM
Bob (Breathing Observation Bubble) joe_cope Boat Design 5 01-30-2007 05:48 AM
Twin outboard separation Archive Powerboats 4 12-03-2005 03:38 AM
Maximum radius for good water separation jfblouin Boat Design 0 10-31-2005 02:30 PM
captured air bubble boat ? lobsterman Boat Design 7 03-29-2004 09:00 PM
