#31
While the lower solid stay could be mounted directly to the normal tack hole on the stem head, the sail's own tack could be mounted on a simple pivoting arm that caused the sail tack to move forward when stay-hinging occurred. Among other advantages, the lower-mounted spar need not ever lower, being at waist level, but instead the sail foot could be undone (e.g. by pelican hook) and it raised to furl with the rest of the sail. With the spar within reach at all times, I'd feel more secure. The vang could have its own turnbuckle to allow adjustment of the clew height at any time, especially when underway (the vang's position would roughly follow the sail's foot). I could draw this... A. |
#32
Yes, I cant claim originality with the 'spin' concept. Harryproa's, model yachts and a lot of other boats have the Baelstrom spar idea working successfully. I dont think it would be much faster across the deck than other alternatives either. The trick is to be able to use the balancing spar with roller reefing. The 'unused' extension has a lot of potential for all sorts of strange attachments. The use of the spar as a launch tube might mean an unnatractively thick spar, but it might work. The problem with using a 'vang' on a more standard jib boom is that you have to have the boom up fairly high to get enough leverage to hold the end of the boom down. |
#33
| Having had a boomed jib , my opinion is they SUCK. The boom will trash about when hoisting or lowering sail and is a sure ankle breaker when working on the foredeck to put on a larger sail. The boom needs a mounting post back from the forestay , to allow the sail to flatten or get greater draft downwind. The only solution for lazy folks is to copy the Dutch river work boats. With a large overlaping jib a heavy eye would be worked into the sail , before the mast. A line would be rove from side to side through the eye. On tacking the sail would take care of it self , the luff would start to work as soon as it was full, only for long tacks would the area behind the eyelet need to be sheeted for a bit more area. FF |
#34
| "The problem with using a 'vang' on a more standard jib boom is that you have to have the boom up fairly high to get enough leverage to hold the end of the boom down." True. The solution described puts the boom at maybe waist high above the deck to reduce the distortion of the sail (100 sq ft jib, e.g.). The vang then follows (roughly) the foot of the sail, allowing a reasonable angle. The whole system of vang and boom would appear to have nothing supporting it (from pushing forward at the forward end of the boom). Yet as it is pushed forward, the forestay tightens---- only the triangle at the foot of the sail (maybe 10% of the sail) is distorted--- until you see that the sail's tension is on the boom and not the original tack of the sail, which can be moved forward for better sail shape at the bottom. A. |
#35
| Not quite sure what you are meaning there. Unless you get about a 45 degree angle on the vang, the downward pull is largely negated. If the tack of the jib is 3 inches off the deck, and the vang is three feet long, then the "angle of the vangle" is too obtuse, and has no downward pull. If you raise the tack off the deck, you lose performance. And as for thrashing jib booms, that only occurs if you dont have roller reefing. Thus the reason I was excited about the combination of balanced boom and roller reefing. |
| Canters tacking | usa2 | Sailboats | 19 | 07-11-2010 09:10 PM |
| Self tacking jib versus overlapping. | Omer | Sailboats | 9 | 08-03-2008 01:44 PM |
| Trimaran - tacking probelm | Sailingpeanut | Multihulls | 8 | 08-10-2007 03:53 AM |
| low-aspect foils and tacking | rayaldridge | Boat Design | 0 | 07-12-2006 05:44 PM |
| self tacking jib roach | Pieetry | Sailboats | 0 | 07-24-2003 03:25 PM |
