Old 03-01-2008, 11:03 PM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 203
Self-steering concerns- multihull vs monohull
I understand how a monohull can be controlled with a windvane, but how could something like a multihull make use of similar self-steering gear (without resorting to electronic means). Wouldn't the greater speed (relative to the wind) make a windvane less sensitive and finicky?
I am typing this in regards to use on 40' cruising boats. An open bridge-deck cruising catamaran vs a typical performance-cruising monohull, perhaps with more emphasis on cruising than performance...
Old 03-01-2008, 11:45 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Autopilot is the only way to go.... modern ones for cats (around 40ft) are not such a great problem to set up... solar panels & possibly better batteries (AGM) & have separate sets (Engine, House, Nav) which can be cross linked if necessary...
Old 03-02-2008, 01:47 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Are there real reasons against WindVane or? Just wondering..
Old 03-02-2008, 03:01 AM
masalai
I have only seen windvane steering on small monohull yachts cruising the pacific (Thru Melanesian Islands) and never, anywhere on a cat... Never thought to ask why, as my choice is for autopilot- less to F**k up. Electronics work perfectly until they bugger up then all is lost. but they only bugger-up if something really bad happens, whereas the windvanes were always giving little problems. - - Windvane-steering is not the sort of thing I would be comfortable with or inclined to rely upon. If the wind changes, you follow the wind. If you want to go that way just make sure your boat is well balanced and set the sails...
Old 03-02-2008, 09:07 AM
Sunset Chaser
Rep: 22 Posts: 203
I've heard exactly the opposite in regards to self-steering:
That windvanes were very reliable while the autopilots were always breaking down and behaving erratically.
I know of at least one windvane that has a warranty of 27,000 miles or one circumnavigation...
Old 03-02-2008, 10:01 AM
Rep: 593 Posts: 2,054
Self-steering
Windvanes do not work so well on cats because the apparent wind rotates around when doing anything offwind. This isn't usually the case for a cruising mono.
Use this URL: http://steamradio.com/pipermail/multihulls/ Located here, you will find an archive of all the posted messages over the last several years. There have been some very good discussions regarding autopilot use on a multihull which may be helpful.
Chris
Monohull verses Multihull powersailers / motorsailers brian eiland Motorsailers 257 12-14-2011 12:10 AM
Steel Monohull Richard & Diane Boat Design 6 10-22-2010 03:53 PM
environmental concerns using boat yard paints and other chemicals Kaptin-Jer Fiberglass and Composite Boat Building 44 01-26-2008 11:26 AM
New Monohull/Multihull Hybrid Sailboat tatria Boat Design 9 09-29-2005 10:20 AM
Mast base laminate concerns Craig_Hastie Fiberglass and Composite Boat Building 3 06-28-2004 10:32 AM
