Old 06-15-2010, 01:40 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
Stuff it full of old fishing poles. Or a piece of wood that will fit.
Old 06-15-2010, 02:08 PM
science abuse science abuse is offline
Rep: -3 Posts: 82
Hey.... Bamboo? I could douse it in some West System epoxy.
Old 06-15-2010, 02:21 PM
Cheesy Cheesy is offline
Rep: 189 Posts: 299
That may well work, another option would be to use a wood core and wrap it in glass. The fibre glass rods will be heavy comapared to the aluminium tube
Old 06-16-2010, 09:02 AM
Rep: -3 Posts: 82
I've got a 1/2" dia, 10ft long fiberglass rod coming.
I'm going to try and capitalize on its tensile and compressive strength by pinning it inside the aluminum tube:
The fiber rod is flexible, but in order for it to flex with the aluminum tube, at least one end will need to be able to "slide" freely because the arc that they both for will be different. By securing both ends, and possibly pre-loading the rod, the aluminum spar wont be able to flex without compressing the fiber rod. It will still be able to flex, but it should be limited.
Old 06-16-2010, 04:03 PM
Rep: 189 Posts: 299
You might be surprised by how heavy that will be.... on the other hand you wont be able to break it if it is a good rod
Old 06-16-2010, 04:48 PM
Rep: -3 Posts: 82
Nah I wont be surprised, I've just bit the proverbial bullet and settled for the $11 solution.
I Need Help!!! replace my x-long shaft and lower end with a long shaft and lower end toocanshan81 Powerboats 1 04-07-2009 03:18 AM
how long? longliner45 Boat Design 8 08-26-2007 03:28 PM
Does anyone need carbon fiber? MSM_Industries Services & Employment 0 01-23-2007 11:02 AM
Fiber products shaapoo Marketplace 1 03-27-2006 10:11 AM
