| Scratch Repair I have just purchased a boat that has some deep scratches I would like to fix. It is a laser and it has the usual nics and scrapes along the gunnal and a few on the deck. I am wondering what would be the best way to repair these scarthes. I was thinking I would grind them out with a die grinder/dremel to get a clean edge. Then I would let it dry out for a few days. Now, the question is what to do next? I was thinking about painting the scratches with expoxy barrier coat like Interlux 2000 and then fill it with a puddy. Then I would paint over the area with gelcoat and sand and buff. I starting to second guess myself when applying epoxy paint and the polyester gelcoat and poly bond. I don't have the experience to know if this is a good idea. I want to seal these scratches so they don't take on any water. Can anyone out there give me some advice as to what I should do? Thanks, look forward to the replies. Christian |
| If your grinding only removed gelcoat and the fibres are undamaged then you only have to replace the gelcoat. Just apply gelcoat and cover it with sticky tape while its wet. Squeeze out any excess gelcoat and wipe it away. Safes lots of sanding. Good luck, Karsten |
| Gelcoat Ring repair | rianhanson | Fiberglass and Composite Boat Building | 0 | 04-29-2005 11:23 AM |
| hull repair | eurotk1 | Fiberglass and Composite Boat Building | 13 | 04-17-2005 11:53 PM |
| Quick,easy, chep & permanant repair for VP 200 Series tilt lock Mech | woodstockwizzar | Boat Design | 0 | 11-17-2004 12:01 PM |
| quick, easy and permanant repair for VP 200 tilt lock mech. | woodstockwizzar | Powerboats | 0 | 11-17-2004 11:43 AM |
| Fiberglass repair | tprocurt | Fiberglass and Composite Boat Building | 2 | 11-09-2004 05:01 PM |
