Old 04-26-2010, 05:32 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
Scantlings for an unusual design
I have been asked if it is possible to obtain CE-approval of a rather unusual design.
The name of the yacht is Centerline 40. LOA is 12.15 meter. Approximately 10 have been built during the last ten years. The builder/designer has passed away, and he left no drawings/calculations. A new builder, who owns a Centerline 40, is thinking about taking up production.
The design is unusual because there are no floors to take the loads from the keel! Instead, the keel is attached to a large (L x B = approximately 1.5 meter x 1.0 meter) steelplate, which is laminated to the inside of the bottom shell. In fact, it is encapsulated in the bottom laminate, sort of like the core of a sandwich laminate, but the entire hull is single laminate. The bottom of the hull is completely flat.
My idea is to treat the plate as one single floor, and then do the traditional calculations, but I'm not at all sure whether this is the way to go.
Any better ideas?
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
Old 04-26-2010, 08:48 AM
Paul Kotzebue's Avatar
Paul Kotzebue Paul Kotzebue is offline
Rep: 272 Posts: 244
The laminate should be treated as a fiberglass and steel composite in way of the steel plate. The potential problem I see is at the outboard edge of the steel plate. Floors that support a ballast keel should end at a longitudinal girder strong enough to support the keel load plus the hydrostatic load, or they should attach to a transverse frame the runs to the gunwhale. With the steel plate arrangement, the transverse loads may not be properly supported by the surrounding structure.
Paul R. Kotzebue, PE
www.pkboatplans.com
Unusual Houseboat Question dondelmundo Boat Design 40 12-04-2010 11:28 PM
Unusual boatbuilding technique for steel yachts 26'-40' origamiboats Materials 31 07-28-2010 06:59 PM
Unusual Rudder Design, but is it any goodl? CaptainAB Boat Design 4 08-02-2008 06:23 AM
Feedback desired for unusual powercat Dayneger Boat Design 14 07-09-2008 04:49 AM
Hi! I have an unusual request Lauriewm Open Discussion: All Things Boats & Boating 2 12-19-2004 07:29 AM
