Old 03-12-2003, 06:47 AM
simonech simonech is offline
Rep: 10 Posts: 6
Sails Design
Hello all,
I've just registered to this forum, I found it very interesting.
I'm a sailor and in my spare time I started reading things about sailing phisique...
I'm very interested in the "aereo part" of the problem: the sails.
My question is:
once I decide which shape to give to my sail (chord, camber and so on) how can I enforce this shape in my sail?
A flat sail can take the shape just over a certain amount of wind, but with lower wind, how can I do?
I've know about pannels sewed togheter, but I don't know how to convert a certain airfoil shape to geometry and combination of pannels...
Does anybody can give me some pointer (or explanations) about this topic?
Thank you
Simone
Simone Chiaretta
www.piyosailing.com/S
Any sufficiently advanced technology is indistinguishable from magic
Old 03-13-2003, 11:19 PM
Rep: 1493 Posts: 7,447
Are you trying to go hi-tech or cutting "on the eye".
Old 03-14-2003, 02:53 AM
Rep: 10 Posts: 6
I intend to cut panels.. no hi-tech... just learning the basics of broadseam...
But how do I desing the panels?
Th
Simone Chiaretta
Old 03-14-2003, 07:28 AM
To get the shape from flat panels, one edge is curved. That is, the camber in the sail will be determined by the curve cut into it. Think of the staves in a barrel. A sail is similar. The curve on the edge of the panel will follow the curve of the camber you want. Of course this is a bit simplistic, since the mast, boom and batten also affect the shape. It is a starting point. Some of the new sailcloths are very rigid. They are much more difficult to shape. I think it would be easier to work with a softer material. Also, if you want reefs in the sail, the very rigid sailcloths make it hard to work with.
Old 03-14-2003, 08:35 AM
Rep: 10 Posts: 6
Ok, but what I was looking for was:
I want the max camber at 40% of the chord... so I'll have to do a curved panel with the maximum width at 40% of the lenght, but is there any formula about the width difference form max to min panel width to have a prefixed camber?
Thx
Simo
Old 03-14-2003, 11:11 AM
This is an aproximate formula that works pretty well. Calculate the camber in pecentages of the length of the panel. The curve of the edge on the panel will be proportional to the camber. For example, if at 40% the camber is a curve with a height 12% of the cord, at 40% the panel needs to be cut 12% of its width. Remember that sails twist, so the camber needs to decrease on the upper panels.
Old 03-14-2003, 11:20 AM
Rep: 10 Posts: 6
Ok. I'll give your formula a try.
Thank you very much
Simo
Old 03-14-2003, 11:22 AM
I checked out your website. What's the video about? I couldn't access it.
Old 03-14-2003, 11:34 AM
Rep: 10 Posts: 6
eheh.... can u read italian?
u entered in my gf section (history of D).. she is a video artist, and the video is protected because it's under work
Old 03-20-2003, 04:50 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
go here: http://www.sailcut.com/ and check out Sail cut 4
Paul
Old 04-09-2003, 10:05 AM
giramonti giramonti is offline
Rep: 10 Posts: 10
A book on the topic
I suggest you read Tom Whidden's book, The Art and Science of Sails. It will give you a very good base in sail design. The book is a long read, and a lot of what is covered is not relevant to actual design, though there is some vital information inside. Topics covered are twist, camber, max draft, longitudinal camber distribution, and more that I can't remember. The book definitely covers design, but barely covers construction, which is what I think you're looking for. Another book is Brion Toss' "The Sailmakers Apprentice." I have to admit, I didn't really like the book because the techniques are old, or more positively, they are fundamental, and I'm more interested in modern sailmaking techniques. If I remember correctly, that book does cover building draft into a sail, sewing techniques: batten pockets, grommets, luff rope, etc.
Both books are expensive so you'll probably want to look before you buy to make sure they have the info you want.
Roberto Giramonti
Old 04-09-2003, 10:12 AM
Rep: 10 Posts: 6
Thank you very much... I'll look for the second book.
Anyway, your is a very nice company
thank you
Simone
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Master in yacht design ambas Education 26 05-11-2006 01:47 AM
Looking for the right path to design and build ben_morel Education 44 11-24-2005 03:51 PM
Westlawn Shool of Yacht Design michal Education 9 03-07-2004 08:11 PM
